Old 08-25-2015, 06:35 PM   #1
Captmatt
Front sway bar install question
Picked up a front sway bar and mounting brackets at the salvage yard today. My lower A arms do not have the factory holes drilled. My plan is to mock in the sway bar using the foreword mounting brackets and then locate where the holes need to be drilled on the A arms. I'm thinking that I need to put weight on the suspension to properly locate where the A arm brackets need to be. Does that sound correct ? All help appreciated !!
Captmatt is offline   Reply With Quote
Old 08-25-2015, 06:53 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Front sway bar install question
Yep, that sounds like a plan. Have the arms at ride height to get the hole locations.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-25-2015, 07:32 PM   #3
Captmatt
Great, thank you sir.
