Old 08-25-2015, 11:00 PM   #1
BamaDave
Worried about control arm shaft torque
I put new poly bushings in. Installed the control arms and now I am torquing the shaft nuts. 115 upper & lower. Does that sound right? Pass side looked good. Driver side upper has me concerned. When I got them to 115, the nuts were hardly touching the bushings, I mean I could spin them around the shaft. What gives?
BamaDave is offline   Reply With Quote
Old 08-26-2015, 07:33 AM   #2
chrismoore701
chrismoore701's Avatar
Re: Worried about control arm shaft torque
I could be wrong on this, but tighten the back nuts and then the front, then torque
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 08-26-2015, 08:26 AM   #3
BamaDave
I don't see how that would matter seeing how I have them mounted on the truck. I did not torque them while they were off. Maybe someone else will chim in.
Old 08-26-2015, 12:35 PM   #4
BamaDave
Anyone?
Old 08-26-2015, 01:40 PM   #5
RodsGreen10
RodsGreen10's Avatar
Shaft nuts are 75 ft lbs.
Control arm bushings are 115 ft lbs
Lower control arm shaft u bolts 80 ft lbs
That is per GM Torque Specs.
RodsGreen10 is offline   Reply With Quote
Old 08-26-2015, 07:51 PM   #6
tinydb84
tinydb84's Avatar
I had to trim my poly bushings about 1/16'' to get the washers to touch the bushing when torqued down properly. Don't go to far or you will crush the bushing and clamp down on the arm.
David
Instagram: myfabguy
