Under bed fuel tank with in tank fuel pump for 5.3 swap
I am doing a 5.3 swap and am wondering what is a good brand of fuel tank that is reasonable price wise, I have tried searching but just keep finding the same stuff that doesn't answer my questions. I want an in tank fuel pump for noise reasons, also one that fits under the bed nice and doesn't sit too low, what have you used.
Re: Under bed fuel tank with in tank fuel pump for 5.3 swap
For simplicity, Boyd Welding does a EFI tank with a Stealth Aeromotive in tank pump. Also, comes with sender, get a 0-30ohm for stock gauge, 0-90ohm for many aftermarket gauges. Price works out to be in the ballpark after you cobble everything together independently.
+1 I have a Boyd's tank with EFI in-tank pump and seems to be a nice unit. I haven't gotten my truck on the road yet, but the fit of the tank was great. I had to remove one small crossmember for it to fit.
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
+1, although I have an external pump. I do have the Boyds tank, great folks!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I've used these guys for my swap. Uses the Gen5 camaro fuel pump module. You can run the tank almost bone dry. and if you ever need a pump, the local parts store or dealership can help.
http://www.rickstanks.com/vaporworks-tanks.php |
I run the Boyds tank as well, and many customers have too. Very nice quality tank and what I think is a fair price. Using the EFI, you just run your fuel line to the rail on the engine, and good to go. If it's a returnless system, then you can run the Corvette regulator / filter setup.
http://www.azproperformance.com/Boyd...ill-14004.html |
I just ordered this one last night for the 6.0 swap I am doing. Includes everything.
http://www.ebay.com/itm/Universal-Bo...3D231574228446 |
