Should my vent window open in or out?
Ive searched pics and threads and cannot find my answer. When you open the vent window on your 72 c10, do you push the vent window out to open it, or do you pull it in? Right now, my vent windows push out which makes it so the window blocks any air from coming in the cab. Just want to make sure it was installed correctly.
Junior Member
![]() Join Date: Aug 2010
Re: Should my vent window open in or out?
the back of the window should tilt out, i've always found that if i open them to the max (past 90 degrees) that the passenger side blows lots of air at drivers side and vice versa
![]() Join Date: Jul 2014
That is correct, if you push it a little further it will direct air into the cab.
#4 | |
![]() Join Date: Mar 2012
that is the correct way as shown in the picture
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
full open, it will blow a lot of air into the cab. One of my favorite features of these old trucks.
Figure out what you want--then figure out what you are willing to give up to get it. |
#7 | |
My mirror gets in the way when I try to fold it all the way out but thats an easy fix. I do wish it would open a little further than it does so I could direct more air at my face. I guess I better get my AC hooked back up. I really appreciate the info guys! |
![]() ![]() Join Date: Feb 2009
It's a nice shot of air too, and that's before you open the vents, which I tend to forget is even there. Only downside of that is if you forget it's there, like I did, once opened you get blasted. Mine blew out all kinds of stuff, despite being garaged most of its life.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: May 2012
I agree. love wind wings. Hey, I noticed you have rifle racks! Same ones I had years ago. Love to keep levels in them. Not allowed to have them here. My nannies say.... NO!
White K20 |
![]() Join Date: Oct 2011
I was waiting for a punch line.... I guess I just got old.
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
I feel your pain..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Yup, that's what I call a mixed message!
#13 |
Hahaha! But in Texas the deputies probably pull you over to mess with you over those stickers and not the rifle racks!
White K20 |
#14 | |
#15 | |
Sounds like ur air is hooked up..we used to call it 2-60 air conditioning. 2 windows à 60 miles per hour. |
