08-26-2015, 07:29 PM | #1 |
Headers & A Drop
Folks - need some advice.
I ordered Hedman shorty headers, part number 69016, since my truck is dropped, and these seemed to be the best bet for not dragging a flange on the ground. I went by the shop putting my new engine in today; the engine and trans are both bolted in, all new motor mounts, etc. The tech was having a hard time routing my starter wires so they wouldn't get melted, and wanted my input before he made some changes. Long and short (no pun intended) on the headers is, the fitment is lousy. On the drivers' side, i'd have to change to shortly plugs, and even then the wires will be darned close. On the passenger side, I'd have to do shorty plugs as well, and the collector tube lays right against the transmission "ear", and the flange for mounting the collector is pinned in; I have no idea if you could even run all 3 bolts up into it. To say the least, with what I paid for these, I'm ticked. Last square I did, I used Hooker Super Comps, and they fit incredibly well - no issues with plugs or interference anywhere, but they were full length. So, as you can see in the picture below, that's how much my truck is dropped. For those of you that have been there, done that, do you think this drop would be OK to run full lengths with? Thought and opinions are more than welcome... Jerry |
08-26-2015, 07:46 PM | #2 |
At the body shop.
Re: Headers & A Drop
If $ isn't an issue. Dougs D-310 ceramic
Fit great, don't hang below the rail. They work better with a double hump trans x member. Fit my angle plug darts with out any special plugs and no special tools to change plugs. Or the Patriot clipster for an SBC work but 5/16 flanges can leak vs a 3/8 flange
" That didnt make it any newer " " Dont antique the equipment " |
08-26-2015, 08:13 PM | #3 | |
Jerry |
08-26-2015, 08:20 PM | #4 |
At the body shop.
I know. But when they fall into place with out any drama it was worth it.
08-26-2015, 08:24 PM | #5 |
At the body shop.
These will work or did on my 73.
http://m.summitracing.com/parts/pte-h8021-1
08-26-2015, 10:06 PM | #6 |
Diggin The SquareLife
08-26-2015, 11:27 PM | #7 |
I have the same basic headers less the coating. I have no issue's. I have how ever changed starters to a newer style Tahoe starter. Which made a major difference and I changed the way my wiring harness runs from across the firewall. And now I have it running along the right (passenger side) frame rail toward the front of the engine. So I can keep as little wiring from on top of the engine and intake manifold area. Looks much cleaner.
I would check the tech doing your repairs. I know a lot of techs working flat rate don't like messing with headers or anything not OEM. Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
08-26-2015, 11:56 PM | #8 | |
At the body shop.
Same ones as posted I think, just coated
08-27-2015, 04:33 AM | #9 |
yup same ones I just checked
08-27-2015, 05:37 AM | #10 |
I used Hedman Ceramic Coated Shorty's on my '74. I also used the smaller high torque starter. Everything fit well, though it was a bit tight on the passenger side for one bolt. Don't use the factory Hedman bolts unless you want them to rust and corrode within a few weeks.
Also, toss the Hedman gaskets and get a set of Remflex Gaskets. A lot of racers use them. They are much thicker, compress 50% and you don't have to go back and re-torque the bolts and leaks are history. Well worth the money, especially if you don't want blow-outs and then replace your gaskets while your exhaust is hooked up... I have photos of the Hedman Headers and crusty bolts toward the bottom of page 2 and blown exhaust gaskets toward the bottom of page 3, in my slow-build signature link.
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
08-27-2015, 09:26 AM | #11 |
Don't have any input on the headers but I'm digging your truck! Very nice, I love that color.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint "Cool ain't ever cheap and cheap ain't ever cool" |
08-27-2015, 12:32 PM | #12 | |
At the body shop.
Agreed, although I'm seeing an Ivory roof cap. Good luck with the headers.
08-27-2015, 01:20 PM | #13 |
I had hooker super comps on my C10, I wouldn't worry about dragging flanges at that height.
08-27-2015, 03:25 PM | #14 |
I think you would be fine with full length. I have hooker comps on mine also. Just the plain steel ones. Over 14 years old and holding up great. I've only repainted them twice with VHT aluminum. http://www.summitracing.com/parts/ho...olet/model/c10. I sit a bit low in the front....crossmember to ground 3 3/4", highest point of lower A-arm is 2 3/4", lowest point of A-arm is 2 3/8". I can make it up and down our bumpy, dippy roads just fine. I have scraped a few times but nothing major. I just take certain places at more of an angle now.
I run a mini starter now but the full size wasn't a problem. No problem with the plug wires. I do use sleeves to help prolong the life of the wires from the temps they endure. I use a straight boot on the #5 wire.
Joe __________________________________________ 1975 C10 "Questions are a sign of intelligence indicating a desire to eliminate ignorance" |
08-27-2015, 04:51 PM | #15 |
driving is in my blood
No reason not to run longtubes, and wire burning is something man has struggled with when using headers for decades. Part of the fun, although I guess its not much fun when you aren't doing the work yourself.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
08-27-2015, 05:33 PM | #16 | |
Jerry |
08-27-2015, 05:40 PM | #17 | |
Jerry Last edited by LuvNLife; 08-27-2015 at 06:11 PM. |
08-27-2015, 05:45 PM | #18 | |
I am going to go with full length. I'll post the story below... Jerry |
08-27-2015, 06:08 PM | #19 |
OK - busy day.
I went back over to look at everything early this morning; I try never to make decisions when I'm ticked off, so it was good to walk away from it last night. The only way a plug wire would ever go on cylinder 3 would be to pull the plug, attached the wire, then screw it back in. Even that wouldn't work, due to the sharp angle of the connector pushed against the header tube. same with number 6 cylinder on the other side. I checked out the Accel shorty plugs, but they would only buy me, at most, about 1/2" more clearance, which still has the connector pushed against the header tube. After 3 of us stared at the engine for a few minutes (like staring at it would change things - LOL), the headers came off and got re-boxed. You can't simply return something to Summit once it's been bolted on, got a couple of scratches, etc., so I had to call about a return. Got bumped up the line to a senior customer service tech within less than a minute, and fortunately she's a gear head. We went over every spec of the engine, trans and accessories, and she was totally stumped on why there was a problem. She asked me to hold, and conference-called in a senior tech from Hedman, and we went through all of it, and even he was stumped. He could only guess something went very wrong with one of their jigs during assembly, or maybe human error. So, where we ended up was Hedman recommended going long tube, and using their part number 69096. The Summit rep and I took it from there. She generated the order, gave me a slight price break, gave me 2nd Day Air shipping free, is sending a UPS call tag for the shorties, and I'll get a credit for the cost difference (long tubes are less than shorties). Not a bad resolution. My first choice for long tubes may not have been Hedman, but we'll get 'em on there, and see how they line up. I went over the pictures of them closely, and it looks like plug access sure won't be a problem. Thanks to all of you for your input... Jerry |
08-27-2015, 09:29 PM | #20 |
Love your truck, awesome color. Its badass!
08-27-2015, 09:30 PM | #21 |
What size wheels/tires front and rear?
08-28-2015, 01:34 PM | #22 |
Thanks for the compliment; I knew I wanted something different, and like how easy it is to keep up a light colored vehicle. When I saw this color on a 2013 Bentley, it just really grabbed my attention so I went for it.
The wheels are the newer American Racing PVD chrome, which is actually a clear coat, not chrome plating; piece of cake to maintain. The front's are 18X7's with 3.75" backspacing, and the rears are 20X8's, with 4.5" backspacing and 1.5" spacers to pull them almost even with the wheel opening. Jerry |
08-29-2015, 12:01 PM | #23 |
Where did you get the 1.5 spacers?
08-29-2015, 07:18 PM | #24 |
Had to dig a bit, but here it is:
ProWheelAdapters.com Vehicle Bolt Pattern - 5x127 ( 5x5 ) - Wheel Spacers - (PAIR) Thickness 1.5" Thick - 1/2" Studs $87.54 shipped, with a 15% discount for using their website. They're really nice quality pieces in my opinion... Jerry |
08-29-2015, 08:03 PM | #25 | |
Where did you get those plug sleeves and the metal that is routed by the valve covers? Looks great and the function is pretty sweet!
