Old 08-26-2015, 08:09 PM   #1
Conrad63
Conrad63's Avatar
22" Gm Transport wheels
Hi all.
I want to put a set of the gm transport wheels on my truck, but I know the rear hub is bigger on my 63 half ton than the newer models the wheels are made for. I was just thinking of changing the rear end, but which year did they switch to the smaller hub? Does the 67-72 have the smaller hub?
Any advice would be cool.
I'm doing a 5-6 drop from CPP with the brake conversion and the 22" GMs were the plan.
Conrad63 is offline   Reply With Quote
Old 08-27-2015, 07:57 AM   #2
Conrad63
Conrad63's Avatar
Re: 22" Gm Transport wheels
Has this been discussed in another thread somewhere? My searches came up with nothing. If it was discussed somewhere, would someone be so kind as to direct me to the thread? Thanks
Old 08-27-2015, 10:29 AM   #3
jayoldschool
Moderator
The only thing I recall reading about those wheels is that they are property of GM and not to be resold...
jayoldschool is offline   Reply With Quote
Old 08-27-2015, 12:09 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I don't think they changed the hub size until the early 2000's.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-27-2015, 11:55 PM   #5
NevEno
NevEno's Avatar
Could just use a 1/4" spacer.
You can find me on Instagram @neveno_cten
NevEno is offline   Reply With Quote
Old 08-28-2015, 03:23 PM   #6
joedoh
joedoh's Avatar
it changed in 88 for 6 lug trucks, the centerbore got smaller.
best method is to have a machine shop open up the centerbore, but that costs a bit and defeats the purpose of having the inexpensive transport wheels. 1/4" spacers will fix you up as said, for just the rear. the front would need bored out or pretty thick spacers to clear the bearing hats.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 10-30-2015, 10:13 PM   #7
Magicalzoomer
Here is a link I found for bolt patterns. I think that the Transport Wheels use the 6X5.5 Pattern.
http://4wheelcustoms.com/BoltPatternGuide.htm
Out of curiosity, could you just do an axle swap from one of the newer Suburban/Avalanche 2WD Yukon & Xl/Denali 2WD Blazer/Tahoe/Escalade?
I apologize in advance if this is a poor question.
One other thing I noticed is this sticker on the wheel that says that it is not intended for extended use, which is a little worrying. What are these things intended for anyway?
http://i213.photobucket.com/albums/c...psw6yquk84.jpg
Magicalzoomer is offline   Reply With Quote
Old 10-30-2015, 10:20 PM   #8
BigDan3131
BigDan3131's Avatar
Just like what their called Transport Wheels, most cars and trucks are shipped by rail cars and go thru sand storms, harsh winter conditions and so forth. Those wheels are installed to save the aluminum wheels from those conditions where ever they are stored before moving to the dealerships.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 10-30-2015, 11:19 PM   #9
NevEno
NevEno's Avatar
They also have a DOT stamp on them.
Old 10-30-2015, 11:25 PM   #10
Magicalzoomer
Hey NevEno,
Did you use a spacer to get yours to fit? Any additional mods to get them under the fender? Lookin' good!
Old 10-30-2015, 11:33 PM   #11
NevEno
NevEno's Avatar
Originally Posted by Magicalzoomer View Post
Hey NevEno,
I have 4 wheel disc brakes, on the front they fit perfect and a 1/4" spacer on the back. Thanks
Old 10-31-2015, 12:00 AM   #12
Magicalzoomer
I have a C20. What swap would be necessary to adapt to a 6x5.5 Pattern? My current setup is the stock 8x6.5.
I apologize in advance if this is a poor question. Interested in the disc brake option to go along with it. Thanks All.
Old 10-31-2015, 02:05 AM   #13
lha1992
lha1992's Avatar
So to let you guys know about the GM transport wheels. I work in the Service side of the local GMC dealership here in my city an we get quite a few trucks in with these wheels. Most of the time the trucks (or Yukons/suburbans/tahoes) get these wheels put on them due to rail theft of the rims from the factory which frankly happens a bit with the half-ton crew cab short bed trucks that are built in Silao, Mexico. Suvs are built in Arlington, TX an the 3/4-1ton trucks an single cab trucks are built in flint.
Some Suvs gets the transports but they put them on became from the factory these things don't have the lug nut locks on them so they ship the rims separate when the customer has bought the special rims.
You can go to your local gm dealership parts department an ask them to sell you a set. They all have a core price of like a grand I think? That's with wheels an tires but you just gotta ask. Just thought I'd help you guys out because these are getting pretty popular I can tell.
lha1992 is offline   Reply With Quote
Old 10-31-2015, 02:14 AM   #14
Magicalzoomer
Thanks man!
Old 11-02-2015, 01:01 AM   #15
Ghernandez66
Ghernandez66's Avatar
Buy 1" spacers. 1/4 inch might be too small for rear and 1/2 might be too big to make em work with the stock studs at least that was my situation last week so I ended up going with one inch spacers from summit here check it out!
Ghernandez66 is offline   Reply With Quote
Old 11-02-2015, 10:00 PM   #16
american revolution
american revolution's Avatar
Attachment 1462777
Did you get your wheels local? Looking for a set
american revolution is offline   Reply With Quote
Old 11-02-2015, 11:29 PM   #17
Ghernandez66
Out of state no one has em locally ..
Old 11-27-2015, 01:07 PM   #18
four door
Attachment 1462777
hey ghernandez - i'm confused on what size spacer you used on the rear.
you say buy 1", but also say 1/2" might be too big.
can you straighten me out and tell me what size spacer is used on the truck in your photo?
did it clear the wheel tubs in the rear with this size?
four door is offline   Reply With Quote
Old 11-27-2015, 01:23 PM   #19
Ghernandez66
I got 1" spacers on the truck in the picture I bought em of summit racing
part #TGI-14001-1-KIT they say they're for Toyota but the ones for Chevrolet the center bore is still to small for the drum to fit..
In my truck it won't clear the tubs and that's because of the height I wouldn't be able to go that low with them on also remember my truck is bagged ..
Old 11-27-2015, 01:54 PM   #20
four door
perfect!
Old 12-21-2015, 07:10 PM   #21
64nlo
64nlo's Avatar
thanks just bought a set and wondering the same thing.. thanks for the part number. they run good on the highway?
64nlo is offline   Reply With Quote
Old 12-21-2015, 08:20 PM   #22
shortbed70
shortbed70's Avatar
Attachment 1462777
What is done to your truck to lay that low on these??? I am debating 20's but don't want to modify a bunch of of stuff!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 12-21-2015, 10:54 PM   #23
Ghernandez66
Its bagged of course. also has 2" drop spindles in the front and 2" lowering block with a c notch.
now if you cup your lower control arms you can go a bit lower check this out this is recen picture.Name:  20151212_120858[1].jpg
Old 12-21-2015, 11:13 PM   #24
shortbed70
shortbed70's Avatar
Anything done to the bed floor and looks like no inner fenders up front?
Troy
Big Red Dog build
Old 12-21-2015, 11:20 PM   #25
Ghernandez66
you are correct no inner fenders and also I removed all the bed wood since it was all rotten I only have plywoood holding it for now.
Theres 2 options you can raise the whole floor and end up with a 12" bed or you can do what Im going to do Just let the notch stick up and cover it with some wood make it look like the rest of the bed with strips once its done.
