Sometimes it's the little things...
The throttle has been sticking a bit and the kickdown not engaging so I reversed the connection point of the throttle cable to the inside of the Quadrajet throttle plate which aligned the throttle cable perfectly and whoa what a difference. Better peddle response and when it kicks down it's like a hornets nest was opened on the 350. Now to get a better kick down braket that doesn't require a zip tie
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
Re: Sometimes it's the little things...
Any before/after pics?
Before, sorry not a close up pic
After, still need to look at kick down connection.
I thought zip tie's were standard and coat hangar was hd option?
