Old 08-27-2015, 03:13 PM   #1
craigg1
Installing power steering and disk brakes
Been looking at a 68 GMC truck that comes with no power steering or brakes. If I purchase im wanting to change over to power steering and disk brakes. Im not a mechanic by any means, so wanting to know how hard of a job it is to achieve both? Also, how hard to switch to 5 lug instead of 6? Is there any specific donor vehicles that would work without issue? Thanks.
craigg1 is offline   Reply With Quote
Old 08-27-2015, 04:23 PM   #2
Lou Boffa
Lou Boffa's Avatar
Re: Installing power steering and disk brakes
I'm right there with you. As for p/s, lots of more reasonable upgrades than I did, but I love my AGR variable ratio box and pump. Use the search feature--there is a whole library of great info for different year trucks and different engines. I'd read those first, then start asking more questions. That's how I did it. All the info and expertise is right here. Good luck.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 08-27-2015, 04:29 PM   #3
bill3rail
bill3rail's Avatar
Originally Posted by craigg1 View Post
Im not a mechanic by any means, so wanting to know how hard of a job it is to achieve both? Thanks.
If this statement is true and you do not want to attempt the swap-out, my question is...
How much money do you have to spend after the purchase price?
Ask some local shops that do truck work and they'll let you know labor costs.
bill3rail is offline   Reply With Quote
Old 08-27-2015, 09:51 PM   #4
hardwaycooke
hardwaycooke's Avatar
p/s is a breeze. Just get either a donor/rebuilt/new gear box, hoses, pump and pulley. I used all march stuff ad a new box but either way is good...easy job. Pulley alignment may be your hardest part but just keep trying and it'll line up.
71 LWB
Large Bore 6-71 Blown 383 Stroker
4.11 Motive/EOM Eaton Posi Ported/Polished Carrier
15x8/15x16.5 MT Radials
B&M Pro Shifter
Truck Name- Spike
hardwaycooke is offline   Reply With Quote
