Old 08-27-2015, 06:45 PM   #1
69Tom
69Tom's Avatar
396 BB swap from an Impala
I have a '68 396 and TH400 from an Impala that I am considering putting in my '70 C/10 which currently has a 307 and a 4-speed.
I'm guessing someone out there has done such a swap. Aside from BB motor mounts, transmission crossmember, what else am I going to need? Is the power steering pump going to need to be switched? Pulleys? Any issues with the column shift from a truck with regards to the transmission?
Also, I'm sure the drive shaft will need to be shortened. What's your take, stick with a 2 piece, or no?
Thanks for the help.
69Tom is offline   Reply With Quote
Old 08-27-2015, 06:54 PM   #2
summitflier
summitflier's Avatar
Re: 396 BB swap from an Impala
When I was running a TH400, I had a one piece.
But mine had the 17 inch tail shaft on it. I believe there are 3 different tail shaft
lengths. Also mine is a short bed, I've heard the long beds are more difficult.
Also, I would ask.. stock height or lowered?
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline   Reply With Quote
Old 08-27-2015, 06:57 PM   #3
69Tom
69Tom's Avatar
Mine is a short bed step, and is currently stock height. I was hoping to do a 2/4 or 3/5 drop on it at some point.
Old 08-28-2015, 01:01 AM   #4
ixei
If you need any pictures, the '67 GMC C25 I recently picked up has a '69 Chevelle 396 in it.
I'd be happy to snap a photo of anything for clarification during your install.
ixei is offline   Reply With Quote
Old 08-28-2015, 04:30 PM   #5
69Tom
69Tom's Avatar
Thanks, I'd appreciate it. Do you know if it kept the original pulleys and whatnot? I can't see it making any problems considering how big that engine compartment is.
Old 08-28-2015, 06:31 PM   #6
ixei
I'll grab some photos of the bay after work here.
Old 08-28-2015, 09:44 PM   #7
ixei
Album of a few angles of the engine bay.
Can't wait to replace and clean everything under there...
http://imgur.com/a/QfShn
Old 08-28-2015, 10:07 PM   #8
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I just dropped a 69 396 out of an El Camino into my 72 LWB. I used small block motor mounts on pre-72 big block stands, works like a charm. I have a built 350 Turbo bolted to the back of mine and to my surprise, the cross member and drive shaft(s) bolted right back in the same holes they occupied with the 350/350T factory set up. This motor came with a long water pump set up so nothing off the front of the motor interchanged. Let me know if you need links to power steering brackets and alternator brackets that actually work. ~Ghostrider~
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
