Old 08-27-2015, 08:03 PM   #1
SnS C10
SnS C10's Avatar
well I took my roof skin off and here are the results
Got around to taking the roof skin off. Not sure how many spot welds I drilled out. It was a pain though. Butchered the roof in some places. The rust isn't terrible underneath, probably 4 or 5 spots that need sheet metal fab and repair. going to wire wheel all the rust, por15 it, then put in some insulation.
SnS C10 is offline   Reply With Quote
Old 08-27-2015, 09:03 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: well I took my roof skin off and here are the results
Looks pretty good. Why did you have to remove it?
Jurassic-1 is offline   Reply With Quote
Old 08-27-2015, 09:12 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
He said in his post he's gonna wire wheel it....por 15 it and then insulate it.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-27-2015, 10:25 PM   #4
SnS C10
SnS C10's Avatar
Well I did a patch panel on part of the roof because of some pinholes. I recently noticed some more issues on the roof so I decided to just get in there and fix it all once and for all. Also getting ready to do a shortbed conversion but wanted to get the roof secton completed before that
Old 08-28-2015, 01:06 AM   #5
Softpatch
Softpatch's Avatar
I would open up that "A" pilar and take a look see
(Thanks for the pictures)
what sealer will you be using.?
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 08-28-2015, 09:19 AM   #6
SnS C10
SnS C10's Avatar
Soft patch how exactly do I open up the A pillar?
Old 08-28-2015, 06:51 PM   #7
Cenla 64 Chevy
I'm interested in how you took off the skin. I saw another thread where someone had removed the skin as well and then insulated/repaired a section then welded it back on. Really looks good but don't know if it's something I should worry about at this point. The roof on my truck looks pretty good but it's what I can't see that worries me.
Cenla 64 Chevy is offline   Reply With Quote
Old 08-28-2015, 07:42 PM   #8
SnS C10
SnS C10's Avatar
Harbor freight has a spot weld remover that attaches to your regular drill. I wired wheeled the gutter then center punched each spot weld. I then used the HF tool and it worked perfect. A couple of places i drilled all the way thru on accident but other than that the job wasnt too bad
Old 08-29-2015, 01:06 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its got the monk haircut (aka Tonsure, for a bit of historical knowledge)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-29-2015, 07:48 AM   #10
Cenla 64 Chevy
HAHAHA...pretty funny. Can't wait to see how the repairs come and you get it back on the truck. Are you using a mig or tig welder?
Old 08-29-2015, 12:19 PM   #11
Eric15chevys
Eric15chevys's Avatar
That doesn't look to bad. Mine was about the same plus a huge squirrels nest. I took mine off because when i was cleaning up the seam sealer in the drip rails I realized that half the spot welds did not hit both panels. The seam sealer was holding it togeter. I have been welding in patches across the eyebrow and corners since I took it off. I will post pictures. I also plan on spraying it with lizard skin before I put it back together.
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
Old 08-30-2015, 10:50 AM   #12
Cenla 64 Chevy
I'm really interested in seeing how your repairs come out. Are you using a mig or tig welder to make the repairs? Just curious...I've got a tig machine but haven't started on anything yet that requires welding. I'm still in the dis assembly portion of my project
Old 08-31-2015, 11:12 AM   #13
SnS C10
SnS C10's Avatar
I used a miller tig welder to repair 3 sections on the roof skin. Went pretty well. I havnt used a tig welder in 6 or 7 years so not too bad I guess.
Old 08-31-2015, 11:15 AM   #14
SnS C10
SnS C10's Avatar
Couple pictures
Old 08-31-2015, 09:02 PM   #15
Eric15chevys
I have both mig and tig at the house. I played with the mig a little to save gas and rods. Since it is in the inside and I really don't care what that part looks like, but for the outer edges I will have to tig out. I don't care what the rest of my old truck looks like, but inside the cab right in my face I don't want that all boogered up. I hope to make some progress this long weekend. The temps should not be bad.
from 1960 to 2000
Old 08-31-2015, 09:07 PM   #16
Cenla 64 Chevy
Shaun23a11en...looks very cool and off to a good start...I've got a feeling I won't be able to pass on checking to see if I've got rust there too and maybe a rats nest or two...just looks a little tedious but I'm in no hurry. I pretty much decided to do the door skins to keep from having to buy replacements so it looks like I'll get some practice removing the tac welds..
Old 09-13-2015, 10:05 PM   #17
Eric15chevys
Here is some of my work from this weekend. I cut out the center because it was to thin to clean up. I have part of an extra cab I have been cutting pieces for patches out of. I found a section with a really close contour and started tacking it in. It is tuff to weld to this old metal, but the side you can see looks pretty good before grinding. I took off this week so I have some small goal with sheet metal.
from 1960 to 2000
Old 09-14-2015, 09:53 PM   #18
Cenla 64 Chevy
Nice work...it takes time but it looks like it will come out pretty good once you've been able to grind / sand etc...I can only imagine how much work it would have cost you down the road if you had not addressed this now...that's why I'm pretty sure I'm also going to remove the roof skin to get a good peak at the inside...if it is all good then now foul...if it isn't then at least I can get it repaired now instead of having to go back and redo after I've got everything else done.
