Old 08-28-2015, 02:21 AM   #1
fredscarryall
fredscarryall's Avatar
Project new navy
Bringing this home tomorrow. It's a 1948 with a S10 chassis conversion. I will be attempting a more modern version of an old navy truck
fredscarryall is offline   Reply With Quote
Old 08-28-2015, 02:22 AM   #2
fredscarryall
Re: Project new navy
More
Old 08-28-2015, 02:23 AM   #3
fredscarryall
Front
Old 08-28-2015, 02:24 AM   #4
fredscarryall
Inside
Old 08-28-2015, 02:25 AM   #5
fredscarryall
It has a 327 with a powerglide
Old 08-28-2015, 02:31 AM   #6
fredscarryall
I am putting this in it. It has a 350 with a 327 crank bored 40 over. It's a 333 with a 177 supercharger.it has 600 at the crank. I am putting a 700r4 behind it. Not sure how well the blower will clear the hood. I will not be using these headers
Old 08-28-2015, 03:39 AM   #7
alaska gasser
alaska gasser's Avatar
Nice lookin truck and power plant. You can put about 10 pictures in each post. You don't have to do a new one each time. Should save you some time.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude
http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU
alaska gasser is offline   Reply With Quote
Old 08-28-2015, 11:54 AM   #8
OrrieG
OrrieG's Avatar
Are those 350 heads or did some of the later 327's come with that type head? I'm used to seeing 265-327 with the earlier smooth heads with the powerpac or fuelie camel bumps.
OrrieG is offline   Reply With Quote
Old 08-28-2015, 03:30 PM   #9
fredscarryall
Yes. They are 350 heads.ported and polished. You probably know these blowers require a stock 8.5:1 compression ratio. So they are small port 1.88 and 1.60
Old 09-02-2015, 01:43 AM   #10
fredscarryall
I am going to attempt a bolt on front and rear air ride suspension
Old 09-02-2015, 01:44 AM   #11
fredscarryall
Front
Old 09-02-2015, 01:45 AM   #12
fredscarryall
I am also ordering these
Old 09-02-2015, 02:02 AM   #13
joedoh
joedoh's Avatar
you will love the airbar rear with sleeves, hands down the best ride for the rear axle, better than even a double convoluted bag advantage setup on bar. and if you set your body mounts up right (frame a couple inches above running boards) it will lay running boards. I had a modified s10 airbar with sleeves on my 65 and it rode like a dream, my only advice is to use long travel shocks. oh and make sure to limit the bag travel, sleeves need shocks or something else to limit travel!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-06-2015, 06:21 AM   #14
fredscarryall
Here is my next plan. 8 to 10 inch extenred doors. In need of more leg room because I need to set back the firewall 4 inches to put my blower motor in. While I am at it I am going to change the three window to a five window. I just have to find a boner cab and doors to get started.keeping the s10 chassis idea and still the short bed. Because right now my back frame rails stick out from the bed about 8 inches. I wiil have to set back my Alex 8 to 10 inches. Here's my rough idea. Excuse my third grade drawing skills
Old 09-06-2015, 11:31 AM   #15
Cautrell05
Somewhere in here I saw a pic of an AD that had an extended cab added. Cant Remember where I saw it though.
Nick
Fast, Cheap, Reliable. You may pick two
My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723
Cautrell05 is offline   Reply With Quote
