Old 08-28-2015, 12:16 PM   #1
revjames
Need crossmember help
I have a 63 frame c10. I bought an 85 donor crossmember and rebuilt it. Today I am mating the two and all the bolts align nicely except one on each perch. There is a predrilled dot in the correct location like the manufacturer had that choice but put it an inch over instead. Should I still a new hole in the frame or the control arm "perch" thanks
revjames is offline   Reply With Quote
Old 08-28-2015, 12:26 PM   #2
Re: Need crossmember help
Common issue with the swap. I drilled the new hole in the frame.
Old 08-28-2015, 12:27 PM   #3
revjames
Thank you thank you relieved
Old 08-29-2015, 01:10 AM   #4
Captainfab
60-66 Nut
Yes you will need to drill one hole on each side and elongate one hole on each side.
