08-28-2015, 09:56 PM | #1 |
Type of Lift?
Alright guys I have a 4 inch lift with trail master shocks? But I don't know what brand of lift it is and I need to order spring bushings and don't know what ones to order or does it not matter, another question I have is what's the best way of going about replacing the spring bushings and cab mount bushings.
08-29-2015, 04:41 AM | #2 |
Re: Type of Lift?
Look on the leaf springs see if you find any markings or a sticker.
08-30-2015, 12:11 AM | #3 |
Re: Type of Lift?
No sticker or markings .
Posted via Mobile Device |
09-08-2015, 12:46 AM | #4 |
Re: Type of Lift?
Try posting in the 4x4 section. Should get more hits but they should be pretty standard - I'd measure them to make sure.
60 K20, eaton HO52, T221, SM420, Dana 44 closed 78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open 05 Dodge Ram 2500 5.9 Cummins 4x4 |
10-18-2015, 01:24 PM | #5 |
Re: Type of Lift?
good chance you will have to pull the springs and measure the ID of the spring eye and the width of the spring. Chevy springs may require different width and diameter bushing for the front and rear spring eyes.
To remove the "stock" bushings from the springs... I have had the best of luck by drilling the rubber bushing material out and then pressing out the bushing once you have a fair bit of material removed. |
