Old 09-09-2003, 11:42 PM   #1
DINS 1
DINS 1's Avatar
Question All Owners Of Suburbans With Rear Or Dual A/c
Any suburban owners that have rear or dual a/c I am looking for some info from you. on your rear a/c fans there is a harrison tag (blue and silver tag facing down or to the rear door) that has some numbers on it? please post the numbers and the year and if the a/c is in a rear only unit or a part of the dual a/c with dash a/c and the rear unit.
I am trying to figure out if there are any other GM burbs or vans that have rear a/c units that could work in are old burbs.
Here is a example of the numbers off of my 71 rear only a/c unit. EAB 252-71B
On my 71 unit there are 2 fan motors that have a fan both sides of the motor.
The 72 a/c rear unit that is part of the dual a/c unit looks like it has only one motor with the fan on each side. I have not taken the 72 rear unit cover of to get the numbers.
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 09-10-2003, 08:37 PM   #2
JimKshortstep4x4
Talking
Here is the information on two 72 Burbs with front and rear air
conditioning.
The mumbers are the same on both units and both units have one motor with two fans.
SAE-Air 60 EBA-252-72B
Jim
Old 09-10-2003, 11:23 PM   #3
DINS 1
DINS 1's Avatar
Thanks for the info.
Are there others that can look at there rear a/c units?
Wade
79 RS Camaro
