Old 08-30-2015, 02:37 PM   #1
lovemmth
lovemmth's Avatar
drop spindles
I am in the process of installing a disk kit on my 65 c10. I got the old spindles out and installed the new drop spindles . But when I went to install the tie rod ends they are drilled to be installed through the bottom, stock they went in through the top. It seems to put the tie rod ends at a sharp angle. Is this normal?
lovemmth is offline   Reply With Quote
Old 08-30-2015, 11:58 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: drop spindles
They were screwed up when manufactured. They must install from the top. Been that way all the way up into when GM switched to rack and pinion in the late '90's or 2000's.
Send them back to whoever you got them from.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
