Old 08-30-2015, 06:08 PM   #1
Possmguts
Possmguts's Avatar
Brake lines...
Having a hard time finding full frame stainless 3/8 brake lines for 4 wheel disks...
Could someone please point me in the right direction.. using Wilwood front and rear...
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 08-31-2015, 08:24 PM   #2
rocknss
rocknss's Avatar
Re: Brake lines...
When I converted my Burb to 4 wheel disc I used the stock replacement front to back line in SS which was 3/8 inch.
Steven
69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners
2017 50th Anniversary Camaro SS
2004 Chevy Impala LS
2016 Chevy Malibu LT
rocknss is offline   Reply With Quote
Old 08-31-2015, 08:33 PM   #3
donandal
Re: Brake lines...
3/8 or 3/16 ?
donandal is offline   Reply With Quote
Old 08-31-2015, 09:02 PM   #4
Possmguts
Possmguts's Avatar
Re: Brake lines...
Maybe thats why i cant find what I was looking for.. been searching for 3/8
I was under the impression you had to go bigger than stock when going to 4 wheel disks... does it matter that Im using the 4 piston calipers?
Old 08-31-2015, 09:14 PM   #5
jmking9
jmking9's Avatar
Re: Brake lines...
The tubing size you're looking for is 3/16. Most of the time, the Inverted flare fittings that are used with 3/16 tubing will be 3/8-24.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 08-31-2015, 09:36 PM   #6
Possmguts
Possmguts's Avatar
Re: Brake lines...
Thanks for clearing that up
