08-30-2015, 10:11 PM | #1 |
Don't know what to do
I have converted not only a manual transmission but also got rid of the automatic steering column to a floor shift column now the dilemma is I used the neutral safety switch from the auto column but it the sometime get hit and then will not start and I will need to play around to find the right setting on it to get it back to running what can I do to by pass this and make things run right
Posted via Mobile Device |
08-30-2015, 10:15 PM | #2 |
Re: Don't know what to do
Bypass the switch wire the leads together
08-30-2015, 10:23 PM | #3 |
Which ones I have a light and dark green then there is also I believe one more connector that is two purples?
08-30-2015, 11:26 PM | #4 |
Proprietor of Dale's Corner
The purple goes to the starter, jump them together. That should get the starter working.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
08-30-2015, 11:39 PM | #5 | |
08-31-2015, 05:46 AM | #6 |
Thanks guys
