Old 08-31-2015, 10:05 AM   #1
cv65
cv65's Avatar
65 crossmember
anybody using a bowtie overdrive 700r4 crossmember,how do you like fit etc?
cv65 is offline   Reply With Quote
Old 08-31-2015, 11:29 PM   #2
Captainfab
60-66 Nut
Re: 65 crossmember
You do realize that a '63-'87 factory auto trans crossmember will work just fine, right?
Old 08-31-2015, 11:42 PM   #3
cv65
cv65's Avatar
Re: 65 crossmember
Hi Capt, can I use my stick 65 emergency brake on the factory auto crossmember
Old 08-31-2015, 11:50 PM   #4
Captainfab
60-66 Nut
Re: 65 crossmember
Yes you could cut the pieces off of your e-brake crossmember and either bolt or weld them to a newer factory trans crossmember. This is how the '63-'65 factory auto trans trucks were. Or you could convert your '65 to the '66-'72 e-brake assembly which does not use a crossmember at all.
Old 08-31-2015, 11:58 PM   #5
cv65
cv65's Avatar
Re: 65 crossmember
Thanks for the info, decided to go auto, getting tired of shifting!
