08-31-2015, 06:31 PM | #1 |
Frame swap
Will a 80s c10 frame fit under a 63 cab?
1963 GMC swb sbw 5.3/4l60e porterbuilt From middle Tennessee 60-66 hood for sale or trade for bench seat rust free nose little pin holes on top message for more details.. |
08-31-2015, 07:15 PM | #2 |
Re: Frame swap
It has been done. But it takes a lot of fab work. From what I remember you have to put a body lift under the cab. I think it would be much easier to transfer the front cross member to the 63' frame.
frame swap has been discussed many times here. Here is one example http://67-72chevytrucks.com/vboard/s...ighlight=frame
It only has original paint once |
08-31-2015, 11:44 PM | #3 |
60-66 Nut
Re: Frame swap
This question has been asked many, many, many times. I always answer with don't do it unless your local laws allow and you're building a lifted 4x4. And yes I have done it before. I have a thread that shows the results.
http://www.67-72chevytrucks.com/vboa...d.php?t=481023
09-01-2015, 12:36 AM | #4 |
Re: Frame swap
i put my 69 on a 83 blazer frame and just made my own cab mounts
09-01-2015, 12:44 AM | #5 |
Re: Frame swap
and you have the correct w/b?
ron |
09-01-2015, 09:40 PM | #6 |
Re: Frame swap
no i cut over 30 inches out of my box
