08-31-2015, 07:52 PM | #1 |
The T5 has arrived!
10 minutes from my house, rebuilt , S10 tail stock already installed with mechanical speedo, Bell housing, and hurst shifter....I can't complain at all. I even saw the parts that were removed and replaced. The guys place was antiseptic . Then he took me to see his sons awesome 62 that had a T5 already. Amazing. Only is I didn't have my phone to snap the truck. Sometimes you get lucky. A big thanx to Lugnutz65 and his blog too!
08-31-2015, 08:55 PM | #2 |
Re: The T5 has arrived!
Schweet...is it a WC? Do you know the ratios?
`63 C-10 Shortwide Roller 305 LT1 cam, Eddy 500 T5 |
08-31-2015, 09:10 PM | #3 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
08-31-2015, 09:16 PM | #4 |
jealous!!!.. i'm in the market for a t-5 currently
09-01-2015, 10:24 AM | #5 |
Not to hijack but while were on the subject of bell housings: I'm still running the iron bell with my T5 hanging out unsupported on the back end. I've read, from reliable sources, that the T5 will suffer no stress from this mounting and in fact mine has been this way for about 3 years in regular use even hauling loads and pulling trailers.
Besides the obvious issue of having to modify the E-brake mechanism, another thing that keeps me from making the change is wondering if cutting out the orig. bell housing cross member wouldn't compromise the frame design, although I know it's done all the time.
09-01-2015, 10:39 AM | #6 | |
I agree that the original cross member for the cast iron bell is structurally important. I think the factory AT trucks with the Powerglide had a cross member at a different location on the frame. People chop out the MT crossmember all the time when they install a 700R4 or other AT and then they just add a different cross member. This is stuff you already know, I'm sure. It seems worth noting that folks who do the 700R4 swap don't seem to have any issues later. There are many opinions about the use of a tail stock cross member with the T5. I plan to add one but will run without it for at least a year. (I have spare T5s sitting around. Heehee.) In my opinion, any tail stock cross member added to a T5 must NOT restrcit torsional forces. The S10 and Camaro tail stock mount had only ONE bolt below the rubber bushing so the T5 could "twist" slightly if needed. I won't go into more detail here, Contact me by PM if you'd like to discuss this further. Back on the OP topic, that T5 should service your 283ci well and you get to keep the cable speedo on the instrument cluster. Hooray for you! Nice!
09-01-2015, 12:54 PM | #7 |
Hey guys sorry been busy at work... I'd like to use the factory one if I can...my gear ratios I think are 2.78 to .63 ...I am going to just lower and space the E brake set up...seems easy to me! I think I will also install my own version of a cross member on the tail of the t5
09-01-2015, 01:42 PM | #8 | |
09-01-2015, 02:04 PM | #9 | |
09-01-2015, 05:31 PM | #10 | |
I'm of the opinion that a 0.63 OD will probably work well with a V8 engine, but not with a 230ci or 250ci. A 292ci might be able to run a 0.63 OD gear and still perform well. Here is some data to chew on. I've chewed on it for a while. I tend to research everything. I love factual information. These statistics are straight from GM Heritage Center documents for the 1988 Camaro. 1988 Camaro The Camaros with a 350ci TPI engine never had a T5 from the factory. GM never produced them. The 305ci V8 TPI (5.0L with a LB9 code) had 220HP at 4400 RPMs and came with 3.08 rear diff standard (optional 3.45 rear) and 5th gear was 0.63. The 305ci V8 TBI (5.0L with a LO3 code) had 170 HP at 4000 RPMs and came with 3.08 rear diff standard and 5th gear 0.63. The 173ci V6 MFI (2.8L with a LB8 code) had 139 HP at 4900 RPMs and came with a 3.42 rear diff standard and 5th gear 0.76. Tire packages on the 1988 Camaro P215/65/15 Standard = 26" tire diameter P245/50/16 Optional = 25.6" tire diameter 1988 Camaro curb weight 2 door hatch = 2975 lb 2 door convertible = 3270 lb 2 door IROCK Z28 = 3149 lb 2 door IROCK Z28 convertible = 3272 lb V8 Camaro highway RPMs 3.08 rear diff with a 26" tire and 0.63 OD gear at 65 MPH is 1630 RPMs 3.08 rear diff with a 26" tire and 0.63 OD gear at 70 MPH is 1755 RPMs 3.08 rear diff with a 25.6" tire and 0.63 OD gear at 65 MPH is 1655 RPMs 3.08 rear diff with a 25.6" tire and 0.63 OD gear at 70 MPH is 17.83 RPMs A 1963-65 C10 short bed step side has a curb weight = 4100 lb A common tire size for a 1963-66 C10 is 235/75/15 diameter = 28.9" Another common size is 235/70/15 diameter = 28.0" IMPORTANT 1963-66 trucks are about 1000 pounds heavier than the 1988 Camaro. 1963-66 C10 highway RPMs with a 3.73 rear 3.73 rear diff with a 28.8" tire NS 0.63 OD gear at 65 mph is 1776 RPMs 3.73 rear diff with a 28.8" tire NS 0.63 OD gear at 70 mph is 1912 RPMs 3.73 rear diff with a 28.0" tire NS 0.63 OD gear at 65 mph is 1833 RPMs 3.73 rear diff with a 28.0" tire NS 0.63 OD gear at 70 mph is 1974 RPMs
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. Last edited by Lugnutz65; 09-01-2015 at 05:40 PM. |
09-03-2015, 11:45 PM | #11 |
That may be because they couldn't really handle the torque of a 350. Many were rated at only 230 lb/ft. I think the max was less than 300, and that was with a tall first gear (lower number).
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
09-02-2015, 09:55 AM | #12 |
The side benefit to keeping the iron bell is use of the old style starter that mounts to the bell and not the engine block thereby avoiding the starter shimming pageant.
I miss the ratios from the S-10 T5 I first had. 1st gear was a little lower and I often treated it as a creeper gear, starting in 2nd unless loaded or on an up-slope. OD was right in the sweet spot RPM for my local highways. Now with the .63 5th I'm never getting to 2K revs even. I'm thinking a 4.10 rear gear swap would help all around. Currently 3.73 and 28" tire.
09-02-2015, 10:16 AM | #13 | |
09-02-2015, 10:18 AM | #14 |
09-02-2015, 10:25 AM | #15 |
I dont know where a 305 is happy on the highway,changing to 410's would set you at 1860 @ 60mph and 2015 @65 mph
09-02-2015, 11:29 PM | #16 | |
A 283 might be happier at 2200.
09-02-2015, 10:21 AM | #17 |
Good score on the T5! You'll love it.
(X2) big thanx to Lugnutz65. His how-to's have helped me a bunch.
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
09-02-2015, 10:27 AM | #18 |
Post Whore
My tremec has a .82 od and the truck has 3.73's with a 30 inch tire. I believe the other option was .64 but that was too much for me. Passing acceleration in 5th is enjoyable. lol 65-70 should be around 2300-2500 rpm.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-03-2015, 08:58 PM | #19 |
All good info guys ...I can't wait to see how she works
