Old 09-01-2015, 07:17 AM   #1
jabos
lower steering column bearing
Working on replacing the bearing and I have the lower shaft out and the inner part of the bearing is stuck on the upper shaft and not sure how to get it off of there, I tried to pry it off with a screw driver and it won't move. Any thoughts?
jabos is offline   Reply With Quote
Old 09-01-2015, 07:51 AM   #2
Blown06
Blown06's Avatar
Re: lower steering column bearing
If you have a Dremel with a cutoff wheel, or any grinder and cutoff wheel. Use the cutoff wheel to slice the race almost all the way to the shaft, then wedge a chisel into the slot and hit it with a hammer. This will split the race and relieve enough pressure that it should slip right off the shaft.
Here's a link to a video that I found describing what I'm talking about. I've rarely had to cut both sides but it will give you a general idea.
https://www.youtube.com/watch?v=BIMt0WGmwxQ
Me: Jarrod
My project: http://www.67-72chevytrucks.com/vboa...d.php?t=646563
Blown06 is offline   Reply With Quote
