Old 09-01-2015, 01:16 PM   #1
BRassi85
1969 C20 Lowering Questions
Just trying to figure out what to do with my 69 C20. I'm building more of a slammed ratted shop truck so I have no intentions of painting or anything. I am wanting to lower it as low as possible though. I found DJM has a -5/5+ kit for the C10 trucks that comes with new upper and lower A arms. Will these bolt onto my truck? I was told by DJM "They would probably work but I would most likely have to change out the ball joints" Only reason I'm looking at this is because its the only A arm kit that I've found that will give me a 5" drop and let me keep the drum brakes.
Any advise, info or suggestions would be appreciated.
BRassi85 is offline   Reply With Quote
Old 09-01-2015, 03:14 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 1969 C20 Lowering Questions
thoughts of changing to 1/2 ton?
Swap everything out and you can make it easy. Drop spindles and bags, should get you there plus your driveability would improve imo.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-01-2015, 03:18 PM   #3
BRassi85
I've considered swapping it to a half ton but that would still be the same question. Would the half ton A arms work on a 3/4 ton truck? If they would I would think that if I just put 3/4 ton ball joints in the A arms I would be at the same place for half the cost. I kinda like the thoughts of keeping it all 3/4 ton. All I'm planning to do for now is a coil spring drop. I just want to get it as low as possible and figured by changing out the A arms I could replace all of my bushings while I was in there.
Old 09-06-2015, 02:24 AM   #4
Mmorgan32
Mmorgan32's Avatar
Pretty sure the half ton and 3/4 uppers are the same I know the lowers are different they have bigger ball joints for 3/4. How are you lowering your front. I'm in the same boat as you I'm considering don't by an axel flip for 5 in of drop but don't know what to do about the front so I can keep my drum brakes. I can't afford to swap in discs and have to buy new wheels to fit over the calipers
1972 gmc c15 short bed... Sold
1970 chevy custom camper patina daily driver
Mmorgan32 is offline   Reply With Quote
