Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 09-01-2015, 01:50 PM   #1
mikesacs
mikesacs's Avatar
burb rear quarter panels
I've noticed that our reproduction parts suppliers now have a fleetside shortbed body panel. Any idea if the bulk of the panel can be used on our suburbans? Is the wheel opening the same shape? I have a lot of the lower rust and around the wheel.
http://www.classicparts.com/1960-66-.../#.VeXjiJeBub8
mikesacs is offline   Reply With Quote
Old 09-02-2015, 12:51 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: burb rear quarter panels
the lower 1/2 could be used for a patch panel, the 1/2 ton panels and the burbs used the same wheel opening as the short bed truck.
you would still need to do fabrication at the rear where the sub is all rounded by the bumper.
if the bed side is built correct the lower 1/2 should be spot welded to the top, the top 1/2 should be a thicker gauge metal, but you would not need that piece.
the inside of the wheel well lip, and the lower portion of the 1/4 panel on the sub is thicker (not trimmed down as much as a truck) where it welds to the inner body structure. this is another portion where you might need to fabricate.
Old 09-06-2015, 06:19 PM   #3
mMad Dawg
Have a look at the lower box rear repair panels for 73-87 chev pickups. I used some of that to get the rounded part at the back by the bumper. Sorry no pics my panel is at a friends acreage. Hope this helps. Gord
mMad Dawg is offline   Reply With Quote
Old 09-06-2015, 11:25 PM   #4
jonzcustomshop
1961 crewcab
good tip! I have one of those boxes, that will help on mine
Old 09-07-2015, 03:22 PM   #5
piratexpress1369a
piratexpress1369a's Avatar
is good to know thanks guys
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
