Old 09-01-2015, 11:07 PM   #1
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
LSx radiator hose sizes?
What are you guys using for your LS swap radiators? And what are the hose sizes? It seems that radiator hose sizes vary from radiator suppliers. I've found some that use 1-1/2" for both upper and lower, some use 1-5/16" for both upper and lower and some use 1-1/4". I measured the upper and lower connections on my LS3 and found that the upper connection (not the barb) is 1.3", which is close to 1-5/16". The lower connection is 1.56", or 1-1/2". Thanks.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 09-02-2015, 10:30 AM   #2
MalibuSSwagon
Re: LSx radiator hose sizes?
I used the stock radiator Spectra CU840.
Truck water pump and t-stat housing.
With 1" set-back plates, the stock 2k Silverado upper and lower hoses lined up perfectly and fit the radiator.
MalibuSSwagon is offline   Reply With Quote
Old 09-02-2015, 09:26 PM   #3
truckdude239
truckdude239's Avatar
I used a griffin ls swap radiator
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
