Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 09-02-2015, 01:30 AM   #1
argonaut
argonaut's Avatar
Removing "Custom" Moldings?
How the heck do you get the moldings off without messing them up? Is there a trick to getting the to the clips and getting them to release? Can someone with experience please educate me on this?
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-02-2015, 05:59 AM   #2
gostranger
65 suburban vortec 5.3 bagged
gostranger's Avatar
Re: Removing "Custom" Moldings?
I have used a kitchen spatula in the past wiggling it under and pulling on it take your time so it doesn't get bent! hope this helps
gostranger is offline   Reply With Quote
Old 09-02-2015, 08:58 PM   #3
padresag
the clips on the doors are nutted on the inside the door
ron
padresag is offline   Reply With Quote
Old 09-02-2015, 11:00 PM   #4
oem4me
I recently used two thin flexible putty knives. One 3" against the body to protect the paint, another 1-1/2" on top of the 3" to pry the trim outward. Also flood the clip/hole area with WD-40 so the spring clips let go easier. Easy does it now!
EDIT: The trim I pulled was narrow fleetside door/side trim, NOT suburban trim. I assume the clips are similar, but I have no actual experience with the Sub trim, sorry.
Old 09-02-2015, 11:29 PM   #5
69chevytrucker
69chevytrucker's Avatar
if you are talking about the ones down the side that are about 3 inches wide then you need to see where the clips are and push the clip on one side to make it turn its flat and goes from the top to the bottom so push on the top to the left or right and it will pop out the bottom
69chevytrucker is offline   Reply With Quote
Old 09-03-2015, 12:44 AM   #6
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
I did mine recently.
Just use plastic pry tools, or putty knive
Slide along under trim, and twist they pull pop right out
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
