09-10-2003, 11:27 AM | #1 | ||
my rearend just started to...
Ok yesterday my ( it sounds like the rear end area ) started squeakings when I take off. But ass soon as I start to slow down it starts to fade out. When I accelrate it starts again.. you get the point. What can be causing this? I guessed wheel bearings? any other ideas?
Rich rtorres(at)buttecounty(dot)net @ . ( so I do not start recieving spam email )
09-10-2003, 11:35 AM | #2 |
could be as simple as replacing the u-joint... get both wheels off the ground, put it in neutral and get the tires spinning, or you might have to have it running in gear to make the noise happen... either way, you should be able to pinpoint the noise...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
09-10-2003, 11:45 AM | #3 | ||
ThanksWill try that asap.
Rich
09-10-2003, 12:00 PM | #4 |
Just make sure you take the proper precautions when running in gear... do it on a flat surface, block the front wheels in front and back of the tire, and have someone around to shut it off if necessary while you're having a look...
09-10-2003, 01:44 PM | #5 |
Live life and be happy.
You're talking truck right? LOL Sorry couldn't help it.
09-10-2003, 01:47 PM | #6 |
Might be that anoying center-support bearing (if you have one). Sometimes when that rubber boot wears out it starts making funny noises. Either that or you've got metal-to-rubber contact.
If it's a metalic sounding squeak but it's not constant it might be your brakes. Sometimes when drum brakes get old and they heat up due to several quick stops the material can shear off, and get melted to the inside of your brake drums over time. It will squeak until you put on the brakes. I know it sounds funny but it's happened to me before. Sometimes it gets so bad you have to have your drums re-turned. Other than that wheel bearings would howl ALL THE TIME. You'd get no peace whatsoever. If it's in the rear-end it will get worse over time until you start getting vibrations. If that happens I'd guess your pinion bearing or your carrier bearings.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
09-10-2003, 01:50 PM | #7 |
Cantankerous Geezer
Lubricate thouroughly with Preparation H. If that doesn't work, best way to check your u-joints is with a prybar with the tranny in gear and the wheels locked. See if the u-joint moves. I would guess, thought that it's a wheel bearing. Take em out, clean and inspect if you can't find anything else.
Fred There is no such thing as too much cam...just not enough engine. |
09-10-2003, 01:54 PM | #8 | |||
Rich
09-10-2003, 02:10 PM | #9 | |
Low & Slow
70' C-10 LWB Fleetside 4.5/6 drop |
09-10-2003, 02:29 PM | #10 |
hehe nope but it works...
01-25-2004, 06:58 AM | #11 |
Its Magically Delicious
whats invloved with replacing the rear wheel bearings ??
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. Last edited by 71-longbed; 01-25-2004 at 07:11 AM. |
