Old 09-02-2015, 09:14 PM   #1
hotrodder
Just bought me a 85 swb. advice on lowering
I just upgraded to a 85 swb !!! Just sold my 67 stepside and got a 85 swb, I need advice from you guys on lowering the truck. I can,t afford a high dollar drop kit, so how is the best way to do it without spending a big wad of cash?
I'm sure this has been gone over many times, but I am new to this site. Been over on the 67-72 side.
hotrodder is offline   Reply With Quote
Old 09-02-2015, 11:17 PM   #2
TrailerTrash
TrailerTrash's Avatar
Re: Just bought me a 85 swb. advice on lowering
what is your budget?
TrailerTrash is offline   Reply With Quote
Old 09-02-2015, 11:19 PM   #3
UKNOWME
UKNOWME's Avatar
Spindles, cut a coil from front springs and install this flip kit http://67-72chevytrucks.com/vboard/s...d.php?t=674969.
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 09-02-2015, 11:20 PM   #4
UKNOWME
UKNOWME's Avatar
Not sure how low you want to go either.
1964 Chevy c10
Old 09-03-2015, 09:37 AM   #5
Aaron_L
That's cheap for a flip kit. If you can weld you can buy new leaf spring perches and weld them to the bottom of the axle. I paid $16 for the pair I bought at a local dirt track shop. However for $40 to your door you can't hardly beat it
Aaron_L is offline   Reply With Quote
Old 09-03-2015, 12:20 PM   #6
SkinnyG
SkinnyG's Avatar
I paid $12 at my local Chrysler dealership for a pair. #4120074
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 09-03-2015, 01:31 PM   #7
hotrodder
the flip kit seems like the way to go for the rear. Whose spindles would you say are the ones to use? My budget is in the 300.00-400.00 range. Would I need to have different shocks? Bear with me here I'm new to this sort of stuff.
Old 09-03-2015, 01:35 PM   #8
hotrodder
Probably 4-6 drop or so.
Old 09-03-2015, 02:01 PM   #9
mongocanfly
Post Whore
mongocanfly's Avatar
Way back when I had my 86 and not a lot of money I simply cut one coil off the front and took 2 leafs out of the back..results were about 2/3 drop...total cost $0.00.
But I did go back and put air shocks on the rear so I could haul my junk..I've got a buddy now with a 4/5 drop on a 86 with 18/20s and it looks great but he said if he had it to do over he would go 3/4..he said it gets aggervating on our ruff roads..
Old 09-03-2015, 03:51 PM   #10
SkinnyG
SkinnyG's Avatar
With spindles and a coil cut, you can use stock shocks in the front.
With a flip kit and shock extenders, you can use stock shocks in the rear. Otherwise use 73-87 4x4 front shocks in the back (gotta finagle the bushings a bit to make it work).
With a notched frame and a flip kit, the stock shocks, even with extenders, will be too long. With the 4x4 shocks, notch, and flip kit -the bed floor will rest on the pumpkin when fully loaded.
I will likely add helper bags to mine, since I ~do~ haul stuff, but I love the 5/6 drop.
Old 09-03-2015, 04:15 PM   #11
ultrahd4me
ultrahd4me's Avatar
You can get a 4.5/6 drop very easy with your truck. 2-1/2 drop spindle (Summit racing $250) & 1 full round off your stock springs (2" drop) gets you to 4-1/2. On the rear I use DJM flip kit with the shock extensions ( Summit racing $80) that gets you 5.5-6". New stock length shocks ( $80-$100) on all 4 corners and your good to go with the same ride quality to have now. You will have 3-4" of clearance before hitting the frame rails with this setup, so I don't run a c-notch. Here a few pics of my trucks with this same setup. I hope this helps.
ultrahd4me is offline   Reply With Quote
Old 09-03-2015, 09:04 PM   #12
hotrodder
That is the look I am after!! Thank you for the info and price break down. The truck has 285/50/20,s. Think these tires are too big for this type of drop?
Old 09-03-2015, 09:23 PM   #13
ultrahd4me
ultrahd4me's Avatar
The tires are 245/40/20 & 275/45/20 on torq thrust 20x8 & 20x10
Old 09-03-2015, 09:25 PM   #14
UKNOWME
UKNOWME's Avatar
I think I asked you on another thread but what backspace are you running? Also are those mass produced or custom made offset?
1964 Chevy c10
Old 09-03-2015, 09:37 PM   #15
ultrahd4me
ultrahd4me's Avatar
Just standard one piece wheels. The 20x8 are zero offset (4.5 backspace) and the 20x10 is +6mm offset (5.25 backspace). I also run a 1-1/4 spacer to bring the tire out as far as possible without rubbing.
Old 09-03-2015, 09:42 PM   #16
hotrodder
They are just Boss mass produced. I 've only had the truck for three days so I haven,t measured any back spacing. Guess I should be better prepaired for this question
Old 09-03-2015, 09:56 PM   #17
Houston Ben
Houston Ben's Avatar
From my experience I would go spindle and flip kit. I did a 2/4 and found one of my spindles to be bad and the rear leaf spring mount was a PITA to get off.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 09-03-2015, 10:07 PM   #18
mongocanfly
Post Whore
Dang it ultra hd..those are some super nice squares you got there...
Old 09-03-2015, 11:06 PM   #19
UKNOWME
UKNOWME's Avatar
And where are you getting your spacer?
I'm running a 4.5 BS front but with a 275 tire and I rub on the right front fender. I have a brand new set of 255s I could swap out. I'm running a 5.5 rear BS with a 295. Think I could still run the spacer?
1964 Chevy c10
Old 10-22-2015, 07:37 AM   #20
Desert1957
Desert1957's Avatar
Bump
I am also curious about this 1 1/4 spacer, More info please.
Desert
Desert1957 is offline   Reply With Quote
Old 10-22-2015, 07:43 AM   #21
Aaron_L
Probably a wheel adapter, not technically a spacer.
Old 10-22-2015, 07:52 AM   #22
ultrahd4me
ultrahd4me's Avatar
I guess a wheel adapter is probably correct. They are 1-1/4" wide made from billet. I've put them on them on at least 12 trucks of my own and several I built for friends with zero problems. I buy them from my local wheel shop but they can be purchased online too. I think they adapt GM 5on5 to 5on127.5mm
Old 10-22-2015, 07:54 AM   #23
ultrahd4me
ultrahd4me's Avatar
As a matter of fact, I just put them on my latest truck just last week.
Old 10-23-2015, 04:40 PM   #24
calvin78612
calvin78612's Avatar
Which flip kit on summit are you using ? Do you have a p/n for the spacers ?
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 10-23-2015, 04:47 PM   #25
ultrahd4me
ultrahd4me's Avatar
Here you go: DJM Suspension Flip Kits FK1024-5, I'll get the wheel spacer info this weekend.
