![]() Join Date: Nov 2006
whats this wire for ?
on the battery cable positive there is a small wire like #12 or 14 size that goes about 6-8" to a small bakelight block with a stud in the center. could somebody tell me the purpose of this and where it goes ?
thanks bob
I BELIEVE IN JOHN 3:16 |
Re: whats this wire for ?
I think your talking about the junction block on the passenger fender. It is a distribution block for positive power wiring. Look up some schematics here if you'd like to know where those wires go.
It's also entirely possible you have an aftermarket positive cable with a small gauge lead that runs anywhere a previous owner wanted it to. |
![]() Join Date: May 2013
Probably the charge wire for your battery ,, they were ridiculously small from the factory
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
Here is a thread with information on the fusible link.
http://67-72chevytrucks.com/vboard/s...d.php?t=545962
Scott |
Old member
The block on the passenger side fender is to attach hot wires off of instead of the battery it self.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
THATS the one I,am referring to fellas
the gray ones your battery charge wire/ power to fuse block , the black one Im not sure traced it back the loom to a junction by my horn relay , unhooked it , cant figure what it was , it was defiantly factory installed just like the picture , on a 67 , have not had an issue , there was a small glass fuse in it
#8 | |
![]() Join Date: Mar 2012
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
great info , I made the switch to a volt meter , probably why I have no issue
![]() Join Date: May 2014
Never knew this! Exactly where are these fuses? Might be why my amp meter doesn't work.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
![]() Join Date: Dec 2006
I just replaced one today. Just look in the corner next to the pos. battery terminal. Follow the small gauge wire coming off the little distribution block there.
Then look in the area of the voltage regulator. Same size and color, same style pull-apart in-line fuse holder.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#12 | |
