AC Compressor button switch
In the process of replacing my heater core this past weekend, I managed to break the ac compressor button switch (I found the wires dangling still attached to the terminals). I have a new part, but I don't which side to affix the green wire and which side to affix the yellow wire. Since the button switch seems to merely open and close a circuit, I don't know if it even matters. I used the search function to find many threads on the ac, but not one specific enough to answer this question. Any advise is appreciated.
Hook'em |
#2 | |
Old member
![]() Quote:
It's the same wire and you are just breaking the circuit. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: AC Compressor button switch
Thanks, Andy.
Hook'em |
Old member
