Old 09-03-2015, 10:17 AM   #1
ubtripn
ubtripn's Avatar
Will this kit work for my 68?
Or will I need ot buy anything else? Thx for the help.
http://www.classicpartsusa.com/produ...68_Truck_Parts
ubtripn is offline   Reply With Quote
Old 09-03-2015, 10:29 AM   #2
ubtripn
ubtripn's Avatar
Re: Will this kit work for my 68?
I also forgot to ask, will my existing booster work for these brkaes, I already need a new master cylinder.
Old 09-03-2015, 12:07 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Since you linked parts to fit a 1968 truck, and yours is a 1968... I'd have to say... yes?
Except those are 5 lug rotors.
Your booster should work, but you will need a master cylinder for disc/drum.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-03-2015, 12:28 PM   #4
Wizo
Wizo's Avatar
Your booster should work, but you will need a master cylinder for disc/drum.dont forget you will need a portioning valve for disc brakes
Gary
Wizo is offline   Reply With Quote
Old 09-04-2015, 12:14 PM   #5
ubtripn
ubtripn's Avatar
Thank you, I just bought new six lugs rims so I don't mind. I just wanted to make sure there was not some part missing that I would have to buy later. Thank you for looking for me and letting me know.
Old 09-04-2015, 12:19 PM   #6
michael bustamante
michael bustamante's Avatar
you might want to call and verify that those inner and outer tie rods will work with your 68 centerlink.
1967custom
michael bustamante is offline   Reply With Quote
Old 09-04-2015, 01:16 PM   #7
Xeen
Xeen's Avatar
If you are going to stay with a 6-lug wheel but are going to disc brakes then you need to buy a kit that is specifically designed with that in mind, they are out there so you can get it done for sure, just make sure that's what you are buying from the jump and you won't have any compatibility issues with your current set up.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-04-2015, 02:07 PM   #8
michael bustamante
it looks like the kit hes inquiring about is a 6 lug rotor kit. also ask of the brakes will work with your drum brake lines and if youll need to swap to a newer or universal prop valve
1967custom
