09-03-2015, 02:11 PM | #1 |
How can i start the motor???
I am in the process of deconstructing my truck and have decided to sell the motor/trans since it will not be going back in. I have removed all of the wiring harness (cab and engine) as it will be replaced also.
The gentleman that is coming to look at the engine really wants to hear it run, if just for a moment. Not an unreasonable request. All of the engine is together, starter is still on, spark plug wires, coil, battery cables, fuel line, everything is connected except the wiring harness is unplugged at the firewall. How can I accommodate this guy?
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
09-03-2015, 02:19 PM | #2 |
Re: How can i start the motor???
run a wire from the dist to the battery, connect starter to battery and jump the starter. pour a small amount of gas in the carb, and check the oil!!
1967custom |
09-03-2015, 03:56 PM | #3 |
You can do as suggested, with a bump starter which is a hand held push button. You can video it and save that video so you don't have to fire it up for every tire kicker that shows interest.
09-03-2015, 04:25 PM | #4 |
videos a good idea.
1967custom |
09-03-2015, 08:20 PM | #5 |
Thanks... somewhere I have a video I think...
09-03-2015, 09:48 PM | #6 | |
The Older Generation
Also, don't forget to hook up an oil gauge unless you want an oil shower.... LockDoc
09-03-2015, 10:08 PM | #7 | |
It went off like a cannon. And all the beams in my garage ceiling are permanently preserved! |
09-03-2015, 10:34 PM | #8 |
Who will build the truck after its taken apart?
09-08-2015, 05:31 PM | #9 |
Does the wire from the battery go to the + coil or to the distributor? I'm trying to do the same thing here but have no spark to the plugs
1949 Chevy 3100 Five Window 1964 Chevy C10 Lambrecht Auction project 1967 Chevy SWB K10 1967 GMC K15 Project Build thread- http://67-72chevytrucks.com/vboard/s...72#post6502772 1968 Chevy Anniversary K10 1991 K5 4" Lift 35's (the wife's toy) |
09-10-2015, 12:21 AM | #10 | |
If you have the older separate style coil/distributor, your distributor needs to be connected to the coil like this http://farm9.staticflickr.com/8144/7...e2a9eac6_b.jpg but your wire colors will probably be different.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
09-10-2015, 10:13 AM | #11 |
I got it running yesterday, here is what I did...
1. Positive side of the Battery to Starter 2. Negative side of the Battery to the Block 3. Wire from Distributor to Negative side of the coil 4. Wire from Positive side of the Battery to Positive side of the coil 5. Gas can to fuel pump 6. Oil Pressure gauge hooked up 7. There are three connections starter. Middle one is the larger one for the Positive cable from the Battery. I hooked up my bump-start button to the Positive side of the Battery and to the INSIDE connection on my starter. Pumped the gas a couple of times, hit the starter button, fired right up. I only ran it for a minute, just to let him hear it, but if you are going to do it for any length of time, make sure that you have water connected or hook up the radiator.
