Old 09-03-2015, 07:25 PM   #1
kryszkuk
72 K20 brake help
I've scene it posted before but can't find it now so sorry for the repeat question in advance.
I can't get my 72 k20 to stop. Changed the master cylinder, wheel cylinders, all rear brake springs and shoes, rear hose and brake fluid. Bench bled the MC, reset the proportioning valve, adjusted the shoes tight to the drums, and bled the brake lines till I got good clean fluid. My peddle goes down 1/2 to 3/4 of the way then good and hard. At a speed of maybe 2mph it stops on a dime but anything over that its like I have grease in my brakes, it barely stops. The only other thing is at idle and in park if I step on the brake peddle the RPM's go up a tad then go back to normal. Is it the proportioning valve or brake booster? Any advice is appreciated
kryszkuk is offline   Reply With Quote
Old 09-08-2015, 12:40 AM   #2
VonDog
VonDog's Avatar
Re: 72 K20 brake help
I'm no expert but it sounds like the booster to me. I'd check the vacuum lines and put a gauge on it to make sure you're getting the right pressure. The pro portioning valve reduces the flow to the rears so you're not locking the rears up.
60 K20, eaton HO52, T221, SM420, Dana 44 closed
78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open
05 Dodge Ram 2500 5.9 Cummins 4x4
VonDog is offline   Reply With Quote
