Old 09-03-2015, 08:21 PM   #1
WorkinLonghorn
WorkinLonghorn's Avatar
Cig.Lighter connection in back
Hi. My cigarette lighter is missing the wiring and I was wondering what type of clip or connector is supposed to fit that little post in back. I tried to get a female "bullet" connector to fit but the smallest size I could find ( .154"?) was too big.
I have the same issue with the temperature sending unit. It too seems to require a female cap of some sort.
Any of you guys know what part I should be looking for? Thanks- Brian
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 09-03-2015, 08:28 PM   #2
hugger6933
Re: Cig.Lighter connection in back
Try a small spade terminal
hugger6933 is offline   Reply With Quote
Old 09-03-2015, 08:30 PM   #3
EARNHARDT#3
EARNHARDT#3's Avatar
It slides on from the side. Kind of an oddball.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 09-03-2015, 09:40 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
There is a regular cigarette lighter wire loom that plugs into the "CIG" terminal in the fuse box and onto the post on the cigarette lighter. It is a pretty simple setup. I don't know if they are reproduced or not. There is a picture of them in this thread. (post #2, picture #1)
http://67-72chevytrucks.com/vboard/s...d.php?t=530583
LockDpc
Leon
Old 09-03-2015, 10:20 PM   #5
Kaptain Kadian
Kaptain Kadian's Avatar
I bought the whole plug and harness from classic parts. Plugs right in
Kaptain Kadian is offline   Reply With Quote
Old 09-03-2015, 10:31 PM   #6
Kaptain Kadian
Finally found the item $15.95
http://www.classicparts.com/1967-72-...Pb9KPGx.mailto
Old 09-03-2015, 11:50 PM   #7
FirstOwner69
FirstOwner69's Avatar
Here's a link to the temperature sensor connector you asked about.
http://www.repairconnector.com/produ...Connector.html
The connector on the lighter harness is shown in the picture below. The terminal itself is very similar to the one in this link.
http://www.repairconnector.com/ford-...14-and-16-awg/
Jim
FirstOwner69 is offline   Reply With Quote
Old 09-04-2015, 01:12 AM   #8
WorkinLonghorn
Thanks guys, exactly what I needed. -Brian
Old 07-09-2016, 11:57 AM   #9
preciador6
Me too.
preciador6 is offline   Reply With Quote
