Old 09-03-2015, 11:58 PM   #1
ivorton74
ivorton74's Avatar
Converting to electric radiator fans
My truck currently has the stock clutch fan but in stop and go and at stand still the temp goes up. So I want to convert to electric but what fans can I use and how do I get em to work? Truck is a 74 with a 99 5.3...has stock replacement radiator
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
ivorton74 is offline   Reply With Quote
Old 09-04-2015, 12:12 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Converting to electric radiator fans
Did you ever put a fan shroud on it? No reason the clutch fan shouldn't be sufficient.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-04-2015, 12:35 AM   #3
ivorton74
ivorton74's Avatar
The engine is sitting forward a bit so when I tried to put my shroud back in it didn't fit
Old 09-04-2015, 10:56 AM   #4
LeesTruk
Maybe this can give you some ideas. I'm getting ready for my 5.3 swap, and like you, am using a replacement radiator;
I decided to use a Windstar fan (2001 Windstar). I had to trim off the mtg. brackets and on three of the corners, move them in to allow for hose clearance. Removed about 1/2" section from the cut corners then plastic welded the corners back in place
I took a piece of aluminum angle, fitted it with 2 mounting posts (10/32 screws), then riveted the angle onto the lower core support
I then drilled corresponding holes in the bottom of the fan shroud so that the fan assembly would be permanently positioned on the radiator. The upper radiator cover will be used to fasten the fan assy. via the original shroud threaded fasteners. I'll do this after the radiator is in the truck. I'll fabricate a couple of brackets to be riveted to the upper fan shroud, then screw the fan assy. to the cover plate
My fans will be controlled by my PCM, but there are numerous fan controls available, including here at this site, or you can make your own
Lee
LeesTruk is offline   Reply With Quote
Old 09-04-2015, 01:42 PM   #5
MalibuSSwagon
I also used Windstar fans, but from a 1995. Fit is great and they cool the engine quite well.
BTW if you had LT1swap.com re-program your PCM, he programs in fan controls so just pin into the PCM at the right spots and done.
MalibuSSwagon is offline   Reply With Quote
Old 09-04-2015, 03:45 PM   #6
Houston Ben
Houston Ben's Avatar
Hey Lee,
How did you attach the fan to your radiator?
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 09-04-2015, 04:03 PM   #7
ivorton74
ivorton74's Avatar
@Lee that's pretty cool man...i should look for some windstar fans...i did have Brendan from lt1swap reprogram my pcm but i rather have a fan control...like use a switch or something
Old 09-04-2015, 04:25 PM   #8
LeesTruk
Ben, if you look carefully at the third picture, you'll see the aluminum angle and posts I attached to the lower core support channel. I drilled two corresponding holes in the lower fan shroud to mount the fan onto the angle bracket. It just slides onto the posts. For the upper attachment point I'm going to use the radiator cover threaded nuts that were originally for the factory shroud mounting. I'll make a couple of "L" shaped brackets to be riveted to the fan shroud and attach them to the factory thread nuts on the cover. I'll do this once the radiator is mounted into the truck, and the cover is screwed onto the radiator support. This will give me an exact mounting location. If the fans ever need replacing or repair, all I'll have to do is remove two screws, unplug the fan harness, and lift the fans out.
Lee
Old 09-04-2015, 06:43 PM   #9
cagodinez
cagodinez's Avatar
LS1Nova what 90 elbow do you use to not hit the shroud? I don't know if to use the radiator and shroud on my 1978 c10 or the one out of the doner 2003 suburban, I have the entire truck.
cagodinez is offline   Reply With Quote
Old 09-04-2015, 09:37 PM   #10
crazy longhorn
Fabricate till you "puke"
How about a 4 row copper/brass rad, with a steel shelf to the back side....sporting 2 /14" flex a lite elect fans. Switched, with painless controls...(on 205/off 195)? She does not ever run hot Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-04-2015, 10:30 PM   #11
ls1nova71
ls1nova71's Avatar
I use the factory LS intake tube. There's pics in the build threads in my sig. Never had one run hot if you get the fan in the middle of the shroud.
Old 09-07-2015, 12:50 AM   #12
Robznob11
Robznob11's Avatar
I'm running a aftermarket vet radiator cost 100 bucks eBay. And I have a dual fan set up off of a v6 camaro I scored for 15$ fit like a glove. Each fan has a pos/neg that a flat blade connector fits right on. I'm using two 40amp relays an 10 ga wire. 30$ thermostat fan controller from AutoZone. It's adjustable. Don't know how much you can see in the pic but you get the idea. I bet a camaro radiator would work too. I run the vet for the built in coolers. I have since went to an aftermarket oil cooler cause my fittings kept leaking.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 09-07-2015, 08:35 AM   #13
MalibuSSwagon
Why? PCM turns the fans on and off when needed, I've never had an issue with overheating.
Old 09-07-2015, 09:18 AM   #14
83 Silverado
83 Silverado's Avatar
Why not just run a Hayden cooling fan controller, you can get ones with a per-set temp or adjustable. I have run both a per-set (185F fan on) and adjustable on two different truck with junk yard fans. It's an easy swap with the controller, just need to wire it to key on power.
83 Silverado is offline   Reply With Quote
Old 09-07-2015, 10:59 AM   #15
Robznob11
Robznob11's Avatar
Originally Posted by 83 silverado View Post
why not just run a hayden cooling fan controller, you can get ones with a per-set temp or adjustable. I have run both a per-set (185f fan on) and adjustable on two different truck with junk yard fans. It's an easy swap with the controller, just need to wire it to key on power.
x2!
LED TAILS
Old 09-08-2015, 03:47 PM   #16
Willie Makeit
Willie Makeit's Avatar
why not let the PCM control it like GM intended? I mean, he is going thru the trouble of transplanting a computer-controlled engine and in order to gain all the advantages that the transplant offers do it as it was designed.
Willie Makeit is offline   Reply With Quote
Old 09-09-2015, 12:35 AM   #17
ivorton74
ivorton74's Avatar
has anyone used one of these universal shrouds? I was thinking maybe I can just get one of these and I can keep my clutch fan. u can see in the pic how close the fan is to the rad. my stock shroud was way too big
