Old 09-04-2015, 07:56 AM   #1
52pickupthegame
52pickupthegame's Avatar
Red face 52 5 win build.
S-10 frame, corvette c3 rear, what driveshaft to use? Im new to this forum. So bare with me. Thanks. I will be posting pics as soon as i find out how. Thanks again.
52pickupthegame is offline   Reply With Quote
Old 09-04-2015, 09:12 AM   #2
63 & 64 Bowties
and a few others
Re: 52 5 win build.
You posted this in the Pre-47 area so I moved it for ya to the 47-59 area.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 09-04-2015, 09:14 AM   #3
52pickupthegame
Re: 52 5 win build.
Thanks.
Old 09-04-2015, 10:29 AM   #4
joedoh
joedoh's Avatar
Re: 52 5 win build.
you dont need a carrier bearing or a slip joint, since the third member doesnt move. I would find a nice silverado longbed one piece and have it shortened
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-04-2015, 11:14 AM   #5
52pickupthegame
Re: 52 5 win build.
Ok koolkool,
Old 09-04-2015, 12:02 PM   #6
Daze57
Daze57's Avatar
Re: 52 5 win build.
that is a nasty good lookin motor sir!
you;ll prolly pass everything except a cop and a red light !
Daze57 is offline   Reply With Quote
Old 09-04-2015, 12:09 PM   #7
52pickupthegame
Re: 52 5 win build.
Yeah its not bad. Thanks. Hey can i pick your brain a lil bit?. Im doing a 52 chevy as it states, i am thinking on using a c3 corvette rear, can i use a drive shaft from a silverado and have it shortened?
Old 09-04-2015, 12:13 PM   #8
Daze57
Daze57's Avatar
Re: 52 5 win build.
should be able too
Old 09-04-2015, 12:13 PM   #9
52pickupthegame
Re: 52 5 win build.
Ok,koolkool
Old 09-04-2015, 02:41 PM   #10
52pickupthegame
Re: 52 5 win build.
Question: How would one find out the year of an s-10 frame if thats all they have. Are the numbers stamped somewhere on the frame. Thanks.
Old 09-04-2015, 08:02 PM   #11
joedoh
joedoh's Avatar
Re: 52 5 win build.
people have told me the VIN is stamped on the top of the framerail in the door area. I have parted a ton of these trucks, all legally, and I have never seen it in person. I even asked guys who told me thats where it was to SHOW me, and nobody ever has.
as long as its an s10 frame and you have a bill of sale for it, I wouldnt worry about the year. 82-03 there werent that many changes, just brake lines and gas tank mounts.
Old 09-06-2015, 09:00 AM   #12
52pickupthegame
Re: 52 5 win build.
ok I see some numbers. and the word PARISH. does that have any meaning. Thanks.
Old 09-11-2015, 03:35 PM   #13
Mike Cordero
Re: 52 5 win build.
S-10 regular cab or 1 1/2 cab? Do frames are same length?
Mike Cordero is offline   Reply With Quote
Old 09-11-2015, 04:37 PM   #14
lv2tri2
Re: 52 5 win build.
Have you looked at the length of the C3 and the width of the bed at the wheel wells?
lv2tri2 is offline   Reply With Quote
Old 09-12-2015, 01:15 AM   #15
joedoh
joedoh's Avatar
Re: 52 5 win build.
I dont understand your question? I have parted reg cabs, extended (1 1/2) cabs, shortbeds, longbeds, all of em. there are three different wheelbases/frame lengths (four if you count a crewcab, six if you count the blazers) I havent found a number on any of them. someone told me there was a secret stamp inside so I actually cut a frame open, and found nothing.
Old 09-12-2015, 08:00 PM   #16
chopit
chopit's Avatar
Re: 52 5 win build.
If you are asking which frame to use for your build...the single cab long bed frame is the correct wheelbase. No, frames are not the same length. excab is longer.
chopit is offline   Reply With Quote
Old 09-13-2015, 08:10 AM   #17
52pickupthegame
Re: 52 5 win build.
Yes, i do have 117" wheel base s-10 frame. I would like to go thru the front end with new bushings n such, so thats y i would like the year of the frame. Or doesnt it matter? Bushings will fit no matter the year as long as it is for an s-10?
Old 09-13-2015, 09:40 AM   #18
52pickupthegame
Re: 52 5 win build.
can I use a chevy 2500 aluminum driveshaft for my 52 chevy build with a 700r4 tranny?
