Old 09-04-2015, 09:13 AM   #1
Ricks1971
Ricks1971's Avatar
2 sizes of lower A arm ubolts?
Getting ready to put the lower A arms on my 67 and noticed that I have 2 different size ubolts? Where can you get the right size ubolts? thanks Rick
Ricks1971 is online now   Reply With Quote
Old 09-04-2015, 10:37 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 2 sizes of lower A arm ubolts?
I recommend upgrading to the larger '73 and later versions. They are beefy 9/16" u bolts that eliminate the breaking issue GM had with the smaller ones. You just need to drill out your bolt holes in the crossmember.
Search for Dorman 13503 for the larger ones. Amazon has them as most parts stores.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 09-04-2015, 12:34 PM   #3
michael bustamante
michael bustamante's Avatar
the 67/72 three quarter ton lower control arm bolts were larger as well
1967custom
michael bustamante is offline   Reply With Quote
Old 09-06-2015, 08:41 AM   #4
Ricks1971
Ricks1971's Avatar
I was able to get the bigger bolts from my local chevy dealer. the part number is 345970
