Old 09-04-2015, 09:30 PM   #1
toolboxchev
More MOTOR!
So I am tinkering with the idea of doing a build to my 010 Gen 1 block using 186 casting 2.02 heads.
Would like to keep the compression with a flat top piston to build ponies but wish to have everyday driving on pump gas.
Is there a way to build a brute and run on regular w/ethanol? I realize I may be asking for trouble.
Carborated, no headers rv-2 cam or higher, with roller hydraulics.
What are your thoughts? Much appreciated
toolboxchev is offline   Reply With Quote
Old 09-04-2015, 10:19 PM   #2
67 chevelle
67 chevelle's Avatar
Re: More MOTOR!
put a stroker kit 383 in the bottom end and those heads , that will definatly put a smile on your face , easy to obtain 400 horse , and better torque , with a 383 , most that have them agree , 383 stroker kits are reasonable as they are by far the most popular , and for good reason , great truck moter with tons of torque
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 09-05-2015, 09:05 AM   #3
Redline novdog
Redline novdog's Avatar
Re: More MOTOR!
If you can port the valve pockets and do a gasket match to the intake, it would be well worth the time. If you would have to have someone else do it,then there are much better flowing heads out there. Edelbrock,World Products,etc...
The stroker crank is a must.NO REPLACEMENT FOR DISPLACEMENT!!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 09-05-2015, 11:32 AM   #4
GMan69
GMan69's Avatar
Re: More MOTOR!
Pump gas? Yes. Regular (87 octane)? Probably not. You would most likely be ok with 91-93. Still pump gas, just costs a little more to pump it.
George Morgan
Hernando, MS
'69 C-10 swb fleetside
'72 GMC swb Stepside
GMan69 is offline   Reply With Quote
Old 09-05-2015, 07:43 PM   #5
Fitz
Re: More MOTOR!
Not enough motor. This one runs GREAT on E-85!
Fitz is offline   Reply With Quote
