WTB: '68 drvr side 4x4 ramhorn
JBarlow is looking for the driver side exhaust mainfold for a '68 4x4. Thanks
Too many is never enough!
ram horn
would he take an a.i.r. manifold? I want to round up some non-a.i.r. manifolds for my '68 so I'd be swapping over. It's the correct manifold for '68 with the casting for the altenator bracket. Let me know and I'll check with Marv to see if he has a set for me or maybe even a couple.
Jason 1968 K10 SWB Fleetside 1971 K2500 GMC LWB 1968 K20 (later frame, donor body) 1972 C20 LWB parts truck 1993 K2500 Suburban, tow rig, 454, 4L80E NEW!! 18' Siem's car hauler 2004 Honda Odyssey (family man!) |
He says that will work.....how much? Thanks Jason
manifold
Just talked to Marv and he thinks he probably has a set. I'll be down there tomorrow and I'll check for sure. Marv said he usually gets $65 to $70 a peice but I'll probably make out at less than half that since he's a friend. How does $25 sound for the drivers side? Would he rather have a non air? If so I'll check if there are two, would cost closer to the $65 though cause it won't be comming from me.
I left Jesse a message....waiting on his reply.
manifold
Go ahead and give me a call when you know the details. How soon does he need it?
Jason,
He will take you driver side for $25. Thanks |
manifold
Not a problem, I'll have it off as soon as he needs it. If I happen to bust out the sand blaster for anything I'll even shoot it. It's in clean shape but I put some bad paint on it originally and it's flaking.
Jason,
Call Jesse at 303-507-5526. I can't find your number to pass it on. |
