Old 09-05-2015, 02:55 PM   #1
T and S
T and S's Avatar
How to Install Hood Hinge Springs
Figured out a way to install hood hinge springs with not much trouble:
A) Tape up edge of hinge ( to help with paint scratching )
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 09-05-2015, 02:57 PM   #2
T and S
T and S's Avatar
Re: How to Install Hood Hinge Springs
B) Install rear bolt loosely (next to firewall)
Old 09-05-2015, 02:59 PM   #3
T and S
T and S's Avatar
C) Pivot up hinge and attach spring. At this point their will be no tension on spring.
Old 09-05-2015, 03:06 PM   #4
T and S
T and S's Avatar
D) Now the fun part. Pull on hinge and pivot down, you will be putting tension on the spring. Align the hinge to the bolt hole and thread in the other bolt CAUTION ! you will have to be careful so you don't cross thread the bolt. Leave bolts loose and remove tape, then tighten hinge ALL Done!
I strongly recommend gloves, and safety glasses for this task. Also, my truck will be a daily driver, so a few scratches don't bother me. But if you are building a show quality build, this method may not be for you.
Old 09-06-2015, 04:44 AM   #5
BigDan3131
BigDan3131's Avatar
Great idea thanks!
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 09-07-2015, 11:58 AM   #6
hubcaplarry
Originally Posted by BigDan3131 View Post
Great idea thanks!
I'll second that!
HCL
hubcaplarry is offline   Reply With Quote
Old 09-07-2015, 12:30 PM   #7
61K10
61K10's Avatar
I bought the cheap hook tool with my new springs. took 2 sec to put the spring on and everything was bolted up. Nice to know another way, thanks for the tip.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
