09-05-2015, 03:22 PM | #1 |
T5 5 speed with low hump floor
My 66 was originally a V8, 4 speed with a high hump floor. I put a T5 in it some time ago. I'm considering putting in a low hump floor, but I'm not sure if it will clear the transmission. I don't want to put one in if I'm just going to have to cut it up a bunch.
If you've done it, what are the results? Thanks Ken |
09-05-2015, 07:44 PM | #2 |
Re: T5 5 speed with low hump floor
I have a low hump with my t5 in a 64
Never drive faster than your Guardian Angel can fly Larry |
09-05-2015, 07:45 PM | #3 |
Had to raise mine 2", now with Porterbuilt stuff a high hump is mandatory!
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
09-05-2015, 08:22 PM | #4 |
Ditto to what Larry64 said. I put a T5 in my 64 C10 with the low hump. Just had to cut a hole since it had a column shift.
09-05-2015, 10:30 PM | #5 |
Here is my 1965 C10 with a T5. Factory stance. Fits just fine.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
09-06-2015, 12:07 AM | #6 |
Great. Thank you. Out with the high, in with the low.
09-06-2015, 08:50 PM | #7 |
Hey 1966SWB... FWIW, I had a little interference problem in my '63 that required trimming a some of the flange "lip" where it was hitting the top of the trans.
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
