Old 09-05-2015, 09:54 PM   #1
64c10HotRodder
Gauge panel installation
I bought this equus triple gauge panel I need help with installing the oil pressure gauge and the water temp gauge . It's a 230 inline 6.
64c10HotRodder is offline   Reply With Quote
Old 09-06-2015, 10:18 AM   #2
Lugnutz65
Lugnutz65's Avatar
Re: Gauge panel installation
You might get a better response in the electrical or engine/driveline section. You gauge set should have instructions to help you. Basically, you will need to remove the oil pressure sensor and install the sender that came with the gauges. Or you could build a "T" and use both. You should have a water temp sensor at one or both of the places marked in the photo.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 09-06-2015, 01:35 PM   #3
64c10HotRodder
So I can take the existing sensors out and put the new ones for the gauges in and it won't hurt anything?
