Old 09-06-2015, 01:28 AM   #1
PeterHall
Door Wire Looms
What are you guys using? I need to run speaker wire into the door and maybe a wire for a puddle light so I dont need anything crazy thick.
I kind of want something like this but cant find a part number.
PeterHall is offline   Reply With Quote
Old 09-06-2015, 09:54 AM   #2
hugger6933
Re: Door Wire Looms
I have a ton of those laying around and have thrown away probably 50 or so from the trucks I've junked out. The hole one the panel really is gonna have to be pretty big for those to "snap" in. You see on the underside of the rubber ring at the ends is a hard plastic ring that the rubber seats into and the plastic also has ears that snap into the panels holes. I may be something like an inch and a half or maybe up to two inches. Check with the companies that make the aftermarket power window kits for trucks and cars, they have them in all different types and sizes, more like half the size of a factory one maybe even more than that. Jim
hugger6933 is offline   Reply With Quote
Old 12-12-2015, 03:10 AM   #3
PeterHall
Re: Door Wire Looms
bump. I tried from things from summit and didnt like them. more ideas?
Old 12-12-2015, 08:07 AM   #4
hugger6933
Re: Door Wire Looms
I see some small ones that look like braided wire I just type in what ever year say 70 C10 and it is always there . Have you seen those?
Old 12-12-2015, 08:30 AM   #5
Grumpy old man
Grumpy old man's Avatar
Re: Door Wire Looms
I just Googled door wire looms and these popped up in 1 second .
http://www.4wheelparts.com/Doors-Doo...FYI7aQodcaECLw
Grumpy old man is offline   Reply With Quote
Old 12-12-2015, 10:18 PM   #6
PeterHall
Re: Door Wire Looms
Do you mean these? Such a big hole!
I bought one of those inclined door jams looms and wasnt quite happy with it. But worst comes to worst Ill use as its probably the best I'll find.
Old 12-12-2015, 11:04 PM   #7
Rod Run
Rod Run's Avatar
Re: Door Wire Looms
I've gotten them out of the junkyard before. That way I had plenty of different ones to choose from. different cars have different sizes, so you should be able to find something that fits your needs
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 12-12-2015, 11:21 PM   #8
Mike C
Mike C's Avatar
Re: Door Wire Looms
Check out the OEM '69 Camaro power window wiring rubber piece. It looks appropriate for these trucks.
Edit: link from first place I found.
http://www.camarocentral.com/1967_19...b_p/dwn-20.htm
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-13-2015, 10:50 PM   #9
hugger6933
Re: Door Wire Looms
The ones from the extended cab[99-07] look about the right size to me look at some of those sometime and if you need them I'll try to round you up a pair and mail them to you. I should have plenty laying around if I can find them. That is the kind of stuff I try to keep for a while then quit trying to keep up with them as I have never needed a replacement one. I've junked a bunch of those out.Jim
Old 12-14-2015, 11:40 AM   #10
mmiddle
mmiddle's Avatar
Re: Door Wire Looms
I've got a couple of set of the type Grumpy posted. Don't really like them. I now have a set from 99-2007 Silverado front doors that I think Im going to us.
I have yet to find any I really like. Especially new.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 12-14-2015, 12:06 PM   #11
Big Kev-O
Big Kev-O's Avatar
Re: Door Wire Looms
I would use the smallest ones I could find if you are just running speaker wires. Anything that has to screw on from the back side is not going to work on the cab side because of the double wall and limited access.
Many options here,
https://www.google.com/search?q=Conv...oe=&gws_rd=ssl
Made in America by Americans
Big Kev-O is offline   Reply With Quote
