09-06-2015, 05:06 AM | #1 |
Extended doors on 50 pickup
Anyone doing or done extended doors on a 47 to 54. I need more leg room with a 4 inch set back firewall. I don't want to do the extended cab with side window look.anyone with pics or advice. I want to extend mine about 8 to 10 inches. Like this rough drawing
09-06-2015, 10:26 AM | #2 |
Re: Extended doors on 50 pickup
Interesting idea. There is a lot of curve front to rear in the door and the roof. Thinking to do it right, new door and roof skins with the correct curvature would need to be fabricated.
09-06-2015, 01:26 PM | #3 |
I'm extending my doors 9-1/4 inches to have the cab work with the standard short bed box on a long bed 1/2 ton frame (GMC frame).
Here is a cut and paste rendition of what it hopefully looks like. I used a photo of a truck that belongs to a guy about 100 miles from me as I didn't have a direct side shot of mine at the time and his has the same chop that mine does. This shows it chopped lengthened and sectioned though. Another cut and paste using Cole Foster of the Salinas Boys old red truck.
09-06-2015, 06:24 PM | #4 |
I extended my 53 five window by 5 inches.
There are numerous sections to the door that needed to be extended, including the area above the glass and the inner door panel. I roll formed the upper door extension cross sections and then added an extension to the door skin that I formed on my english wheel. It has a compound curvature to match the original door skin. The roof panel also required a compound curve panel to extend it. The extension needs to be accurately executed to maintain the parallelism of the window tracks also. mine is just getting ready for paint this winter. |
09-06-2015, 07:17 PM | #5 |
Nice work, I plan to use the front half of one cab and the back half of another both to avoid two seams and the simple fact that I have one cab with a great firewall that is the one I want to use and a bad back side and another cab with a near perfect back side but not so good. The left overs will get used to fix other cabs that I have. I've got a stack of doors and don't really even know how many I have so each door will be made of two cut to fit with one seam.
09-06-2015, 07:53 PM | #6 |
yeah,
that's probably the best way. The cab also tapers wider as you move aft, so my back panel of the cab was widened about an 7/8 inch. the taper could probably handled a number of ways, but you will see when the cab is split in half, and you need a longer section from each donor cab to get the amount of extension you want, that you will see about 7/8 inch taper for every 5 inches of cab stretch. I just finished all my window track pieces and new glass patterns for the 5 inch extension, which also included extending the window roll up mechanism, and all new felt tracks and stainless exterior pieces.( which also needed to be extended). Also the inner door molding was extended. but the legroom is awesome! |
09-06-2015, 08:54 PM | #7 |
also,
the doors seemed a bit flimsy after extending them. I added a pair of custom box beams welded to the inner door panel to strengthen it, and added a custom curved door skin reinforcement beam to the outer skin as well. the outer beam is bolted in place, with mat applied for sound deadening between the skin and the beam. |
09-07-2015, 12:05 AM | #8 |
That is some nice work.
09-08-2015, 04:14 AM | #9 |
I agree with mr48chevy. Take. A good firewall front half and Good 5 window back and weld them together I think that would be easier because you can split the floors. Donaldal looks like you made the door extent easier then I was . I wiil have to use that idea
09-08-2015, 12:38 PM | #10 | |
This is the roof on my truck when chopping the top. The same thing was done on the rear of the cab, there is no weld going through the middle of the cab when I sectioned it. And the cowl. The same idea on the door when they were sectioned. I cut the framing off the skin, sectioned the framing then simply re-rolled the skin welding to the frame and trimming the 2.5 inches off the bottom of the skin. So I would think about bringing the cut back to the rear of the door like this. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-08-2015, 01:01 PM | #11 |
nice work... all of you
i thought of extending my cab thru the doors to give me some leg room thought better of it after i had all the rust repairs done way more work than i wanted to do
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-08-2015, 01:18 PM | #12 |
Agreed, impressive work guys.
Any issues with matching the crown or curvature of the door or roof? I figured that would be a likely place for a flat spot or noticable curvature change. |
09-08-2015, 02:33 PM | #13 |
Martinsr, I'm saving those photos to be able to show a buddy exactly what I have been talking about on the roof of my truck. Thanks.
I'll save the batch for reference. I had planned to do the doors the same way on the section too. Advanced Design I've been pondering the difference in width of the cab when I stretch it 9-1/4 inches. I figure I'll have to do a bit of adjustment to get it all to match perfectly.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 09-08-2015 at 02:40 PM. |
09-08-2015, 02:58 PM | #14 | |
Brian
09-08-2015, 04:06 PM | #15 |
yeah,
Martinsr has a point about the roof weld in the middle. It is a bit tricky. I actually made a roof support beam for the contour of the roof ( with my shrinker/stretcher ) before I welded the main roof skin back in. It was held in with clecos then removed for final welding. It held the curve so well that i kept it and installed mat between it and the roof and bolted it on just above the door headers for a permanent support. |
09-08-2015, 04:16 PM | #16 | |
I have just found that moving the cut over to a better place pays off some big dividends. I certainly didn't mean to say anything negative. Brian
09-09-2015, 12:51 PM | #17 | |
I didn't take any offense. I actually like your way better. I don't have a lot of experience on this type of cab stretch. It worked out ok, but you are right, that long weld across the top really took a lot of time, a lot of patience, and a very deliberate process to keep the whole top from warping. probably the toughest part! thanks |
09-09-2015, 01:26 PM | #18 | |
The top needs to be lengthened when you chop it (or rake the posts) I welded it across the center and warped it all to hell! I put 2 gallons of bondo on that roof before I touched it with sand paper, NO KIDDING! LOLOL I actually Z cut it but not far enough. Plus of course I didn't know how to weld so I welded and cooled the welds BIG MISTAKE. Brian
09-09-2015, 01:46 PM | #19 |
that's the patina I like.
not the truck itself, but those old photos. too cool |
09-09-2015, 02:11 PM | #20 | |
High school parking lot 1977. Brian
09-09-2015, 02:13 PM | #21 | |
Brian
09-09-2015, 02:35 PM | #22 | |
Brian
09-10-2015, 01:53 PM | #23 |
all relevant to this thread martinsr
and very cool
09-10-2015, 05:35 PM | #24 |
It's good info for both guys who are wanting to chop a truck and for guys who might want to stretch the cab for more leg room. As I said earlier I saved several of those photos for reference Referring to and studying good build tips helps all of us build a better truck. On sectioning the truck cab the photos show drilling out the spot welds and slipping the top back down over the firewall and cowl sides may save untold hours for me over just cutting through the middle of the cowl and firewall and welding it back.
