Old 09-06-2015, 03:28 PM   #1
cobraffr
Ignition Wiring 1948
I am trying to wire up a simple ignition system to test run the engine in the chassis. The previous owner had run the engine in the frame, but removed the coil and some of the wiring. I don't plan on using the chassis in my build, but I wanted to get it running for fun and to verify its condition.
I hooked up a 12 volt battery and the engine turns over fine. I bought a generic 12 volt coil and wired it up like the diagram below indicated, but I get no spark. I pulled the cap on the distributor and the the rotor is present and the points open and close.
I have attached a couple pictures of my temporary wiring. BTW my "ignition" switch is to unplug the coil if the engine ever runs.
Any suggestions to trouble shoot this? If I can get spark, I will move on to the carb and fuel system.
Torres 1948 Chevy Truck Build
cobraffr is offline   Reply With Quote
Old 09-06-2015, 05:02 PM   #2
mr48chev
mr48chev's Avatar
Re: Ignition Wiring 1948
I wouldn't hook it up any different if I was doing it.
I am assuming that you have the point gap right or very close to right.
Plus the gap was set with the rubbing block on the tip of one of the lobes of the distributor cam.
If that is right I'd take my ohm meter and check the continuity between the points and the connection at the coil. I've seen the lead from the condenser or points put on the wrong side of the insulator for the screw that goes through the housing before and even did it myself when I was 16 and had a no fire condition.
My ongoing truck projects:
Old 09-06-2015, 10:35 PM   #3
mog797
mog797's Avatar
I am having same problem let me know if u get it started and what u did I will do the same
mog797 is offline   Reply With Quote
Old 09-08-2015, 11:16 PM   #4
cobraffr
Smile Re: Ignition Wiring 1948
Thanks Mr48chev, Apparently at 46 I made the same mistake as a 16 year old. I had attached the black wire between the coil and the points to on the wrong side of the connection. I put it under the nut rather than the metal tab on the side of the distributor. I have confirmed the engine has spark with timing light. Thanks for your suggestion.
I will roll it out of the garage and try to start it next weekend!
Donny
Old 09-09-2015, 11:08 AM   #5
mr48chev
mr48chev's Avatar
I think the list of those who haven't done that is shorter than the list that did make that mistake.
From the time I was a student in high school auto shop I seemed to end up troubleshooting vehicles that others had worked on and couldn't get to run so I have seen about everything that usually happens when someone worked on a rig and now it doesn't run.
Old 09-09-2015, 12:28 PM   #6
OrrieG
OrrieG's Avatar
I have also twisted the connectors just enough that it grounded out on the base plate or external housing too, especially on the older SBC distributors.
OrrieG is offline   Reply With Quote
Old 09-12-2015, 02:35 PM   #7
cobraffr
Success!
https://youtu.be/0Ra6GVySkVY
Needs the fuel system cleaned out and the carb rebuilt, but not bad for being dormant about 6 years.
