Old 09-06-2015, 11:31 PM   #1
freak
Does this tank float look ok?
My truck has been in dry indoor storage since I parked it around 1991. Took the tank out to start fixing the floor and decided to dump the gallon or so of gas still in the tank. I was very surprised when I saw what happened to the float over all those years.
freak is offline   Reply With Quote
Old 09-07-2015, 02:17 AM   #2
toolboxchev
Re: Does this tank float look ok?
Wow, ethanol?
toolboxchev is offline   Reply With Quote
Old 09-07-2015, 08:00 AM   #3
freak
I don't know. I think the ethanol thing is a myth though.
Old 09-07-2015, 11:30 AM   #4
hamjet
hamjet's Avatar
It looks fine, put it back in.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 09-07-2015, 12:09 PM   #5
jayoldschool
Moderator
Most states weren't putting ethanol in fuel in 91. That's simply from condensation in the tank accumulating, then rusting out the float.
jayoldschool is offline   Reply With Quote
Old 09-07-2015, 12:09 PM   #6
hugger6933
A little epoxy and it should be fine
hugger6933 is offline   Reply With Quote
Old 09-07-2015, 12:11 PM   #7
hugger6933
That scares me for all of the ones I have laying around that I'll use some day or unfinished projects that I can't work on due to other things. Jim
Old 09-07-2015, 12:17 PM   #8
leftybass209
leftybass209's Avatar
It doesn't matter if it looks okay, only if it functions okay. You don't see it when it's in the tank anyhow!
leftybass209 is offline   Reply With Quote
Old 09-07-2015, 12:49 PM   #9
bluek5
bluek5's Avatar
http://www.summitracing.com/parts/omx-1772901/overview/
I put one of these in my 72 a couple months back. Even if your float did look ok they develop holes and will fill up with fuel. I would replace it with a factory type brass float or one of the cheap plastic ones in the link.
bluek5 is offline   Reply With Quote
Old 09-07-2015, 03:03 PM   #10
jocko
jocko's Avatar
no wonder half the fuel gauges I've ever had don't work! thx for sharing the link on the jepe float bluek5, I saved that for future ref! I've got two not working right now.
Old 09-07-2015, 03:17 PM   #11
Redline novdog
Redline novdog's Avatar
OMG! those are made of brass or copper aren't they? I think you have a wild animal in your tank ! I wouldn't think they be so prone to corrosive liquids!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 09-07-2015, 07:40 PM   #12
Fitz
Duct Tape, dude, Duct Tape. It is the irresistible force that binds the universe together.
Fitz is offline   Reply With Quote
Old 09-07-2015, 08:18 PM   #13
Mr Handy
Mr Handy's Avatar
ok I was not expecting that... That is funny.
Mr Handy is offline   Reply With Quote
Old 09-07-2015, 08:25 PM   #14
EARNHARDT#3
EARNHARDT#3's Avatar
I don't think it can be considered a float anymore!
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP
EARNHARDT#3 is offline   Reply With Quote
Old 09-07-2015, 08:44 PM   #15
Boog
laying low
Boog's Avatar
Nah, it's one of those cheap imports right?
Boog
Old 09-07-2015, 08:53 PM   #16
bill3rail
bill3rail's Avatar
Looks like water/moisture corrosion. If you have a project lying around with fuel for that long, you may see tanks going bad also.
bill3rail is offline   Reply With Quote
Old 09-07-2015, 08:54 PM   #17
'68OrangeSunshine
'68OrangeSunshine's Avatar
That's the special bevel modification circle track racers had to make, since they're almost continually in a left hand turn. The Float was bevelled to read the fuel that was forced to the passenger side of the tank by centrifugal motion.
When you're turning left, it will all read OK.
Old 09-07-2015, 09:10 PM   #18
freak
Original equipment.
Old 09-07-2015, 09:32 PM   #19
Boog
laying low
Boog's Avatar
It was only a joke.
But I have never seen a brass float eaten away like that. What does the rest of the fuel system look like?
Boog
Old 09-07-2015, 10:06 PM   #20
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Looks like it fits somewhere around the dump.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is online now   Reply With Quote
Old 09-07-2015, 10:28 PM   #21
too much stuff
Roadtrip!
too much stuff's Avatar
Doesn't look too bad, a little spray foam will fix er up...
Here is mine from my 67 i recently pulled.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again...
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-07-2015, 10:33 PM   #22
freak
It was only a joke.
The screen was corroded pretty bad as well.
Old 09-08-2015, 03:17 PM   #23
tdangle
tdangle's Avatar
I had a replacement float get eaten up in less than 10 years. You would think brass would last, but they don't. I do believe the ethanol blend has something to do with it
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 09-08-2015, 04:01 PM   #24
leftybass209
... doing more research.
Old 09-08-2015, 04:18 PM   #25
leftybass209
After some research, the only place that I've seen that has mentioned that ethanol is in fact corrosive to soft metals such as brass and copper, is a reference to US. DOE2006a. I have not yet read that to determine what exactly it says, but it was referenced in the book, Advances in Bioethanol which states;
"Some of the soft metals such as zinc, brass, lead, aluminum, copper are not compatible with ethanol and can suffer corrosion and pitting if exposed to it for extended periods (US DOE 2006b). Furthermore, ethanol dissolves in water and is more electrically conductive than petrol. The presence of water can facilitate corrosion, and the conductivity facilitates the possibility of galvanic corrosion."
