Lift or no lift?
I am in the planning stage of building myself a shop. I think that a lift would be a nice addition. I am unsure which style lift to get. I think that a 2 post lift would work the best. What are some of the disadvantages of this style lift? Other than storage what are some advantages of a 4 post lift? Any input would be very much appreciated.
Thx
======================================== Dennis 37 ford coupe 68 short narrow 72 short wide |
Re: Lift or no lift?
There was a recent discussion on 2 vs 4 post lifts just recently. Check out this thread
2 be or 4 not to be? Lifts, that is the question.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
Thanks for the response.
If you can, do a lift. It gets old really quick crawling under only to find you need a different tool.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
I use my TWO post mainly for raising beds off to place on the dollie I made and cab for replacement and during frame changes. It is real nice to be able to change a body by yourself. Jim
If you can get only one a 2 post is the best way to go. A 4 post has its uses but removing wheels is difficult and the lift itself is in the way. Also get a clear floor two post. The plate covering the cables will always be in the way especially when doing transmission work.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Thanks for the great advice. I am going with a two post for sure.
![]() Join Date: Sep 2015
Check with a local lift sales company. They usually have lifts that they have removed for sale. I bought my 2 post, clear floor 6 ton lift for $1100. One of the best lifts I've ever seen. A lift is like a pickup, once you get one you can't do without it.
If I had the space for a shop, I'd build one too and yes, I'd get a lift.
Best of luck for you. |
![]() Join Date: Nov 2013
Without a doubt...........the best addition to a shop you can get....
![]() Join Date: Jul 2012
My only regret about my lift is I should have purchasd one 10 years sooner.
I just built a shop and left room for a lift. Issues I see with a 2 post lift in once you pick a spot, you're stuck (concrete prep etc,) and if you aren't using it then you risk opening your doors into it.
Benefits for me wanting a 4 post, you can move it around, (even outside), you can store a car on it and lift it up to use the lower space for storage. You do need to tray and a bottle jack though to take off tires.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#13 | |
| Bookmarks |
