Old 09-07-2015, 04:01 PM   #1
72 5500
Big truck cabs 64-66
Are the big truck cabs C-50 C-60 the same as the c-10 cabs???
72 5500 is offline   Reply With Quote
Old 09-08-2015, 12:40 AM   #2
jtrichard
Re: Big truck cabs 64-66
all but the floor...... NO hump ...other thing that may be different is if the C50/60 had air brakes
jtrichard is offline   Reply With Quote
Old 09-08-2015, 12:56 AM   #3
Captainfab
60-66 Nut
Also on the C50 and up cabs, there is an extra brace/support across the firewall, from side to side. This can be removed for use in a light duty truck.
Old 09-08-2015, 01:24 AM   #4
padresag
some door glass had a metal cap around the edges. the rear cab mount was the same as the 20 series
ron
padresag is offline   Reply With Quote
Old 09-08-2015, 02:48 PM   #5
72 5500
Thanks, I kind of thought they were the same size. I have a 64 panel truck that is in need of inner roof rust repair pieces as we as the panel below the air vent box.
Old 09-08-2015, 11:54 PM   #6
Captainfab
60-66 Nut
depending on what you'll have to pay for a whole cab, those pieces are available from the aftermarket.
Old 09-09-2015, 03:18 PM   #7
72 5500
I see they sell the patch panels for above the windshield. I need the section above the door where the door seal attaches to and down the side between the door opening and windshield. I also need the panel below air vent tunnel where the wiper transmission is.
That is the air vent box I poorly described on my last post.
