Old 09-07-2015, 10:11 PM   #1
enigma
HEI fitting question
I have been looking at 4X4 builds and on some builds the HEI fits and some don't. But what my question is does it matter if it is a K10 or K20 stick or auto?
Thanks Baron
enigma is offline   Reply With Quote
Old 09-07-2015, 10:31 PM   #2
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
Re: HEI fitting question
Thanks Baron
Not really, it's because the engine sits far back on the firewall. Fresh body mounts will help a lot or a 1" body lift
68SWB4x4 is offline   Reply With Quote
Old 09-08-2015, 12:18 AM   #3
VonDog
VonDog's Avatar
My 60K20 had high valve covers and a standard points Dizzy. The valve covers hit the firewall and the distributer was close but fit. I tried to put a HEI on but the back was really tight against the firewall. I did a little massaging with a body hammer and made it work. Glad I did it!!!
60 K20, eaton HO52, T221, SM420, Dana 44 closed
78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open
05 Dodge Ram 2500 5.9 Cummins 4x4
VonDog is offline   Reply With Quote
Old 09-08-2015, 12:21 AM   #4
VonDog
VonDog's Avatar
Oh yeah, mine is a standard 4 on the floor.
Old 09-08-2015, 01:12 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Great question..... wish I could offer a definitive answer. Lacking that, I will tell you (In case you are building a database) that it fit my '72 K20 (350/350) just fine. Not a lot of extra room, but nothing hit either. I did have to remove the cap before I could install the HEI.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 09-08-2015, 09:23 AM   #6
enigma
Yes building data base have 383 with tall valve covers (dang roller rockers). Doing most of the work by my self but not the body work. Got a complete rolling chassis just swapping everything over and getting a parts list together.
Old 09-08-2015, 09:54 AM   #7
$20071k10
$20071k10's Avatar
fit my 71 k10 fine 350/sm456. I didn't have to take the cap off to install
Brian
$20071k10 is offline   Reply With Quote
Old 09-08-2015, 11:32 AM   #8
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
From experience
68 K10 327/4 speed not even close. Put a MSD instead and because it was slightly taller than stock I had to take cap off to install.
68 K10 suburban 327/4 speed appears to be same clearance but fresh bushings I will be putting the same MSD in soon and will report back
Old 10-11-2015, 11:16 AM   #9
enigma
Anything new to report there 68?
Old 10-11-2015, 11:11 PM   #10
CCCC
CCCC's Avatar
72 K5 Blazer - Delco HEI went on nicely. Tight but right.
CCCC
67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison
Moved but still in the family
70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350
Recently sent to new homes
72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp
CCCC is offline   Reply With Quote
Old 10-14-2015, 11:32 PM   #11
BigRed76
BigRed76's Avatar
I put an HEI in my '70 GMC K2500 and it fit with no issues. 350/TH350 in stock location.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 10-14-2015, 11:41 PM   #12
71swb4x4
71swb4x4's Avatar
My experience:
1971 K10 350 4 speed HEI fit.
1971 Blazer 4x4 350 TH350 HEI fit.
1971 Blazer 4x4 350 TH350 HEI fit. (another Blazer)
They were all a little close, but they all fit. All had original body mounts, so were probably sagging a bit.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-15-2015, 08:34 AM   #13
enigma
Okay how about tall valve covers???
Old 10-19-2015, 11:12 AM   #14
FlameOut
Aren't there smaller cap HEI distributors? I was about to post a question concerning this and then I saw this thread. I have very little room (maybe 1/8") between my cap and firewall on my 72 K10 w/350 sb. I'm now getting some popping from my exhaust and wondered if maybe it has something to do with my #5 plug wire resting tightly against the firewall. I really haven't done any diagnostics yet to find the problem, but wanted to try a smaller cap distributor
2004 Chevy Silverado Z71 Ext Cab 1500
1972 Chevy K-10 SOLD
1967 Chevelle SS
FlameOut is offline   Reply With Quote
Old 10-20-2015, 08:31 AM   #15
enigma
Hei is a large cap rotor with coil built in on top of the cap.
Old 10-20-2015, 09:21 AM   #16
$20071k10
$20071k10's Avatar
[QUOTE=enigma;7342021]Okay how about tall valve covers???[/QUOT
you will have to change or modify (lengthen) the alt bracket
Brian
Old 10-20-2015, 12:36 PM   #17
FlameOut
What about something like this one? Is this a points distributor or does it need something like one of those MSD modules?
1967 Chevelle SS
Old 10-23-2015, 08:26 AM   #18
enigma
that is more like stock size will fit no prob but will have to have separate coil.
