Old 09-07-2015, 10:26 PM   #1
sherm6413
Ls swap guys help!
Ok so I'm in the process of putting in a 5.3 and 4l60e with the entire cpp swap kit. Well motor and tranny are in and I am trying to bolt tranny crossmember to tranny. When I measure across frame rails the transmission is 1/2" off to the passenger side. Is this normal or don't I need it dead center? I've tried moving over and it's not budging , please any advice is thankful
sherm6413 is offline   Reply With Quote
Old 09-08-2015, 07:31 AM   #2
Re: Ls swap guys help!
Here's a whole forum for LS swap questions:
http://67-72chevytrucks.com/vboard/f...play.php?f=206
Old 09-08-2015, 08:40 AM   #3
67 chevelle
67 chevelle's Avatar
doubt it will make a diferance , dodges are an inch over , and fords are 3-4 inches
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 09-08-2015, 11:42 AM   #4
Aruba1
Are both motor mounts bolted onto the motor? BTDT, my transmission mount was also offset when I had only one side of the motor mount bolted in place. When I got the other side bolted the transmission lined up right in the center.
Aruba1 is offline   Reply With Quote
Old 09-08-2015, 01:08 PM   #5
bs46488
I put a LS in a Nova.
My trans was off to the drivers side, but by the time I got things buttoned up and bolted down, it was maybe 1/8" off. I was able to push the trans into place and put the bolts in.
Between the bolt holes on on the trans and the holes on the mount, there is a lot of wiggle room.
bs46488 is offline   Reply With Quote
Old 09-09-2015, 02:53 PM   #6
sherm6413
yes both mounts are bolted to motor and evenly slid back as far as possible, I can get it close to center but then one motor mount is 3/8 further back than the other. I just don't want my driveshaft off balance
Old 09-09-2015, 08:59 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My motors has a little "hip lean" to the left if you stare at it from dead level. Most do.
FWIW, our entire frames are up to 1/2" off square sometimes more....old tolerances + lord knows how many fender benders and fixes. Some guys frames are WAY off.
There is a cross brace in the rear under the bed on the 64-66's that is 1/2" off on EVERY one I've ever seen.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
