Old 09-08-2015, 12:05 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Can you confirm a big block by VIN with no spid?
Is it possible to tell if a truck is an original big block without the spid?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 09-08-2015, 01:46 PM   #2
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Can you confirm a big block by VIN with no spid?
Lots of things under the hood...
4 row radiator and hold downs
remote power steering reservoir
exhaust heat shield on lower passenger side of cab
And in the cab...
Bolt in high hump (tranny cover)
And on the frame....
Duel exhaust hangers
Someone will chime in with more I'm sure.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 09-08-2015, 02:04 PM   #3
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
The only thing I can confirm at the moment is a high hump. It is a 69 SWB and apparently the PO tried to turn it into a fake super Cheyenne and changed out the glove box door, door panels, etc. The truck is SWB and as you know the value would be much higher if you can prove the truck is a factory big block without the SPID.
Old 09-08-2015, 02:33 PM   #4
Keith Seymore
Keith Seymore's Avatar
Not by the engine code in the VIN.
http://67-72chevytrucks.com/vboard/s...d.php?t=570059
The engine code merely distinguishes between V8 vs 6 cylinder.
Edit: unless it has a 6 cylinder VIN - that would certainly prove it is not a big block.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-08-2015, 02:46 PM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I just went back and looked at the pics and it the alternator is on the passenger side so I doubt it is a factory SWB truck even with the high hump. I didn't see that picture the first time.
Old 09-08-2015, 03:00 PM   #6
TransMan1972
TransMan1972's Avatar
Do you have the engine ? What is stamped on the pad ?
TransMan1972 is offline   Reply With Quote
Old 09-08-2015, 03:00 PM   #7
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
It is a truck on craigslist. I didn't notice the engine pic at first.
Old 09-08-2015, 07:38 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
Are you looking specifically for a cheyenne or cheyenne super? How much are you looking to spend? There are a few in the ark-la-tex area. I used searchtempest.com and found a few.
WIDESIDE72 is offline   Reply With Quote
Old 09-08-2015, 09:35 PM   #9
uncle
The weight can tell you on vin tag. Can't remember off top of my head but it is different.
uncle is offline   Reply With Quote
Old 09-08-2015, 11:39 PM   #10
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
If you find a emissions sticker that reads 402 on the LH inner fender, engine compartment, odds are high it's original. The BBs have a stamped number on them, which you can find through this website. I had thought the VIN stated as well, but it's been a lot of years since I checked.
Like the previous poster said, the weight is different too. You can find that info. on this website as well.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C
I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too.
Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc.
The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.
Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 09-09-2015, 12:18 PM   #11
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
It does not appear that it can be proven to be an original BB SWB truck without the spid or build sheet so I am going to pass on it. I am not in the market for one but was interested in this one for the price listed if it could be proven to be an original BB SWB truck.
Old 09-09-2015, 12:41 PM   #12
Doug's68SS
the tinng i noticed on mine was that the upper frame rails by the exhaust manifolds has been trimmed back for clearence.
Doug's68SS is offline   Reply With Quote
